Closed Thread
Old 06-01-2023, 07:08 AM
Stielow's Avatar
Stielow Stielow is offline
Stielow Engineering
The Following User Says Thank You to Stielow For This Useful Post:
camcojb (06-01-2023)
  #62
Old 06-01-2023, 07:12 AM
Stielow's Avatar
Matt had some rework to the the DSE upper link pockets to be square.
Stielow Engineering
The Following 5 Users Say Thank You to Stielow For This Useful Post:
Aschle (06-01-2023), camcojb (06-01-2023), fleet (06-01-2023), RLEWIS (06-04-2023), WSSix (06-02-2023)
  #63
Old 06-05-2023, 12:29 PM
Stielow's Avatar
There were some questions on the air cleaner and the throttle body. This is another Camaro at Sled Alley.
Stielow Engineering
The Following 7 Users Say Thank You to Stielow For This Useful Post:
89 RS (06-15-2023), BonzoHansen (06-06-2023), camcojb (06-05-2023), fleet (06-06-2023), Goosesdad (06-07-2023), srode1 (06-05-2023), sru1436 (06-05-2023)
  #64
Old 06-06-2023, 02:03 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Originally Posted by bulldog19 View Post
There’s no substitute for cubic inches!
Boost?
They go together like peanut butter & jelly.
Scott from NJ
The Following User Says Thank You to BonzoHansen For This Useful Post:
jarhead (09-04-2023)
  #65
Old 06-29-2023, 04:22 AM
Stielow's Avatar
Default Hobbs Camaro (Old Drag Car)
Some more updates from Sled Alley
I decided to try the stock 12 bolt for this build. It had a crack in one of the tubs from all the drag racing. Matt fixed that and got it tuned up.
We have been have a lot issues with noisy Ford 9 inch rear axles. We put a Ford 8.8 in another build and it is quite. I hope the 12 bolt works better also. Time will tell.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
camcojb (06-29-2023), fleet (06-30-2023)
  #66
Old 06-29-2023, 04:28 AM
Stielow's Avatar
Add
Added the DSE brackets and my axle ends for C6 hubs so I can add ABS. We weld on washers now to enable a clean wiring installation later.
Stielow Engineering
  #67
Old 06-29-2023, 04:30 AM
Stielow's Avatar
Trunk braces and trunk repairs. I have no idea what was in the trunk that pocked these big holes in it.
Stielow Engineering
camcojb (06-29-2023), Sonar Chief (09-16-2023)
  #68
Old 06-29-2023, 06:27 AM
68454RS's Avatar
68454RS 68454RS is offline
Amazing quality of work .. loving it
  #69
Old 06-29-2023, 07:26 AM
Stielow's Avatar
a
These are made out of 304 stainless steel. They make excellent tie down points and they won’t rust. We leave them unpainted. A Sled Alley original product!
Make strapping a car down very quick, safe and easy.
Stielow Engineering
  #70
Old 06-29-2023, 08:47 AM
camcojb camcojb is online now
a
I will definitely give Matt a call when I get to that point, been looking for something clean and secure to tie the car down when trailering. Or to pull it up our steep driveway if it quits at the bottom.
fleet (06-30-2023)
Closed Thread
