Old 01-21-2021, 05:57 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by 67_camaroRS View Post
Mark have ever had issues with the latch in the hood popping open at high speeds? I'm not sure if your using the original latch mechanism. I've noticed many car builders use hood pins and my father before me has warn me about the risk at high speeds. thanks sir.
I don’t like the look or function of hood pins. I have run a stock hood latch on most of my cars.
We ran a test at work to see the force on a hood latch on a 2008 CTSv at 190 mph. It was over 300 lbs of force trying to pull the latch open.
I have not had an issue with the stock latch with my Carbon Fiber hood. But we have a big steel reinforcement plate in the hood that the latch bolts into.
If you want to be 100% sure do some old school hood pins. I personally hate them.
I can say at 170 mph in my cars you can see the corners of the hood being forced up by the under hood pressure. Another reason I have hood vents.
Good luck!
Mark
Stielow Engineering
PTAddict PTAddict is offline
Default Dash
Mark,
I like the finish on your dash - is that just an off the shelf crackle paint or something else?
This build is beautiful. So right in a subtle way, and not overdone. As someone who is trying to emulate much of what you've done in recent builds, one of the hardest things is to keep things simple and logical in both function and appearance.
Latest car: https://lateral-g.net/members/borduin/
EFI Tuner for: http://www.modernclassicsauto.com
Old 01-21-2021, 08:51 AM
Stielow's Avatar
Originally Posted by PTAddict View Post
Mark,
It is our local powder coater wrinkle black powder coat. I like it. It does not scratch and gives a nice look.
Thanks, for the complement. I like simple complex things. This car has a lot going on but it looks fairly simple.
Matt and the gang at Sled Alley do a fantastic job with all the little details.
Mark
Stielow Engineering
Old 01-21-2021, 09:54 AM
67pro-street 67pro-street is offline
This is an incredible build! I can't even begin to imagine the amount of engineering and thought that went into this, but it looks just absolutely beautiful!!
-Aman
1969 Camaro Z/28: W.I.P. Bolt-on Art Morrison MaxG Chassis, LS2 Stroker, 6spd. manual, amongst many other goodies!
Old 01-23-2021, 02:50 PM
wareaglescott wareaglescott is offline
Amazing build. Thanks for sharing the process
Old 01-23-2021, 08:04 PM
syborg tt's Avatar
Evening Mark,
I really love the look of the black finish on the radiator and AC condenser. Do you have any tips or suggestions to get the OE look that actually stays on.
Thanks in advance.
marty-mj
Old 01-24-2021, 05:28 AM
Stielow's Avatar
Evening Mark,
Thanks in advance.
Not to be flippant but hire a good painter. I honestly have never painted a radiator until I did Red Devil and the Dutchboys suggested painting it.
I know this time around they painted them black then applied a satin clear to get the correct sheen.
On my Blazer I used a lot of SEM Trim Black. At home when I need to repair something Trim Black works great.
Good luck
Mark
Stielow Engineering
Old 01-24-2021, 10:10 AM
clill's Avatar
clill clill is offline
LOL....SEM Trim Black makes me think I'm a painter.
Old 01-24-2021, 02:08 PM
You guys buying that high dollar name brand spray paint. I'm over here with ACE satin black going to town on my radiator, lol.
Another great build, Mark. Your team did a great job.
Old 01-25-2021, 04:35 AM
cpd004's Avatar
cpd004 cpd004 is offline
I go back and forth between SEM and VHT rollbar & chassis paint. For me, VHT lays down nicer.
1971 Firebird
2017 SS
