Originally Posted by preston
Are you building new Sutton style "Long" control arms or more of a standard A-arm ?
I've been looking at those Ron Sutton control arms and cannot believe its a good design to have the LBJ hanging out there unsupport/triangulated, but he obviously knows what he's doing.
Hey Preston,
Ron is not changing the control arms on his AMX creation. He is just moving the existing arms to locations to achieve optimum geometry. In his case, as a very talented fabricator, he made cool new mounts.
You are correct in being concerned about the Lower Ball Joint being un-supported. I have seen a lot of LCA designs that looked like they would fail ... and did. The simplest way to make them strong is to triangulate them at the LBJ with both tubes of the LCA. But that doesn't allow us to push the hub/spindle combo deep into the wheel for low to zero scrub radius.
In designing LCA's & suspensions with low or zero scrub radius ... we need to make the front part of the LCA go deep into the wheel. And the tube or strut rod that attaches to the front LCA & triangulates it ... needs to support the LCA out as close to the LBJ as possible ... while still providing high clearance for the wheel to turn. It's a challenge.
The solution is make everything stronger 3 ways with higher grade material, thicker material & optimized design. Where a lot of LCAs are made of 1"-1-1/8" x .095" DOM ... and some .125" DOM ... to make our Track-Star GT LCAs strong enough, we had to increase the diameter to 1.250" ... up the material to 4130 Chromoly ... and use .125" wall thickness in the main tube of the LCA & the Strut rod. The LCA itself still needed more strength, so we increased its strength massively with a triangulated brace support the full length of the LCA ... made from 1" x 2" x .125" wall steel tubing. All TIG welded of course. Lastly ... the strut rod connection needs to go out as close to the LBJ as possible. I designed a clevis mount out of .156" steel that attaches the strut rod closer inward for tire clearance, but extends the support to within 4" of the LBJ. None of this would work if we used the typical 1"-1-1/8" x .095" DOM tubing & didn't add the long 1" x 2" support.
