Old 03-18-2015, 07:17 PM
KPC67's Avatar
KPC67 KPC67 is offline
good info guy's
Kevin Carter
Old 03-18-2015, 07:20 PM
LXSS350 LXSS350 is offline
Smile
I got some new wheels for the JA2.0 project.
These are 18 X 10 mono block wheels that fit over the 394 mm ZR-1 rotors.
With the DSE front clip the ZR-1 wheels don't fit anymore.
Mark
Mark how much room do the calipers have (clearance) to the inside spokes of the CF5? (i.e. could I push the offset further inwards on the both the 10's and 12's) Or is there no space?
Cheers
Colin
Old 03-19-2015, 05:12 AM
Stielow's Avatar
Stielow Stielow is offline
I did 18 x 10 with a 20 mm offset on the front and the caliper has about 5 mm clearance toward the spoke side. It has about 4 mm clearance to the barrel. Not sure you can increase offset and still have them clear the ZR-1 calipers.
Old 04-01-2015, 01:21 PM
aggie91's Avatar
aggie91 aggie91 is offline
Default Updates...
Mark
What is the latest on the work being done to JA?
Karl
1965 Chevrolet C10
1982 Chevrolet C10 - My son's Truck - Sunburn
Old 04-05-2015, 06:34 AM
Stielow's Avatar
Were making progress on JA 2.0. It is back at Sled Alley and Matt is wrapping up some final details.
We reworked the LS9 inlet to get better air flow
The spacer under the lid simulate the spacer C&R is make to allow 40 mm bigger intercooler bricks
In this picture you can see we reworked the fuel rails to help fuel flow. We are running a -6AN line to each fuel rail to keep up with the flow requirements of E-85 fuel.
This is the CAD drawing from C&R showing the spacer
CAD drawing of the bigger custom bricks.
The C&R intercooler made from the Denso 27 mm high efficiency core. It also has the Vintage Air A/C condenser mounted on front of it. It is a very nice package.
You need a lot of airflow and cooling to clear 1000 HP. We should be flowing 1700 CFM of air when we are at full song.
Old 04-05-2015, 06:47 AM
Stielow's Avatar
More cool Sled Alley Fab
Transmission Shifter closeout
Matt made the passenger inner wheel house two piece on JA to make it easy to get the dry sump tank hidden in the cowl area.
Old 04-05-2015, 08:01 AM
glassman's Avatar
glassman glassman is offline
Great updates Mark!!! Very nice progress....
Is that transmission boot adapter plate (third pic from bottom pic) custom or is there a p#? thanx, Mike
Mike
Old 04-05-2015, 08:19 AM
Stielow's Avatar
It is all custom. We made the shift ring and Matt made trans tunnel part with nuts welded into it.
Mark
Old 04-05-2015, 08:28 AM
glassman's Avatar
Thanx Mark. It looks factory, and I wonder if this could nessessitate a demand? cause i need one and i think there are more than a "few of us" doing a T-56_ coversion. Iif the "tabs" were left square, we/whomever could simply bend it to conform any tunnel used....hmmmm
Mike
Old 04-05-2015, 02:36 PM
Vince@Meanstreets's Avatar
Love that shift lever too.
It's tough to make a universal part cause there are so many tunnel styles between models.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
