Old 03-03-2021, 05:53 PM
Duder Duder is offline
That white is the perfect shade of white! Did we ever find the name of which VW white it is?
Old 03-04-2021, 06:48 AM
EVIL SS EVIL SS is offline
It looks exactly like my old 1989 VW GTI and they called it Alpine White L90E paint code but, Maybe it is newer paint code.
Old 03-04-2021, 07:21 AM
Stielow's Avatar
Stielow Stielow is offline
VW Cortina White LB9A 1992 - 2020.
Stielow Engineering
Old 03-04-2021, 02:41 PM
Jim Hoke Jim Hoke is offline
Default Maiden Voyage
Happy for you Mark......... Long road to get to this point, but I think all of us would agree that your cars continue to evolve and improve........... Nice job!
Old 03-06-2021, 11:35 AM
JohnUlaszek JohnUlaszek is offline
Now that I think about I think you are correct on the tank vent. I’ll add a overflow tank in the tank before the TooMuch canister.
Mark,
Overflow isn’t needed, but just one vent on the filler neck and one on the body of the tank, both lines should meet at a T fitting and then a single line up to the IIMUCH VSB.
Old 03-06-2021, 12:08 PM
clill's Avatar
clill clill is offline
The problem I run into with the vent hose hooked up to the filler neck is with a full tank when accelerating the fuel goes up the vent hose into the Too Much canister to the point it fills it up and overflows out thru it's vent.
Old 03-07-2021, 07:38 AM
69hugger's Avatar
69hugger 69hugger is offline
...A condition known as II Much acceleration! 😁
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 03-07-2021, 07:42 AM
Ns RS's Avatar
Ns RS Ns RS is offline
Mark what’s the verdict on the tilton in comparison to the dyad clutch? Car looks great
Old 03-07-2021, 09:19 PM
Blown353 Blown353 is offline
Very interested in your verdict as well, I'm also eyeballing the Tilton ST-246 for my build but haven't seen too many reviews for them.
I had a Mcleod RXT on the shelf but sold it after driving a few that I installed in other people's cars, didn't care for how grabby they were when taking off and also didn't care for the amount of floater rattle in neutral. Hoping the Tilton is better in both areas.
Recently installed a Monster LT1-S twin disc in a supercharged 2006 GTO, and it's a really nice clutch. Drives like a stock GM clutch in terms of effort, engagement smoothness, and noise, but it should-- it's a heavily reworked GM clutch.
Trying to decide between the Tilton ST-246 or a Monster LT1-S triple disc in my car.
1969 Chevelle
Old 03-08-2021, 03:27 AM
Stielow's Avatar
The Tilton is dead quite with the clutch pushed in. The pedal force is about the same as the DYAD. The launch is smooth and chatter free most times. If you lug it and don’t give the engine a few revs it can chatter a small amount. If adapted my launches a little and add 500 rpm and it is smooth.
So far the hi rpm reserve is very good. I have not tracked it yet but form the little bit I have drove it I like it. (I only have 200 miles on the car).
DYAD 7.25/10 rating. Negative rattles at idle when it has some miles on it. It too can chatter sometimes. Need a custom throw out bearing. Great high rpm reserve. Work awesome on the track. No issues.
Tilton 8/10 rating Does not rattle at idle. Does not need a special throw out bearing. Had a small chatter at a very soft launch. I have not tracked it yet.
Mark
Stielow Engineering
