Old 08-06-2014, 05:50 PM
It gets old real quick!!
Pete is here in Sun Valley -- and came down to the shop today. He was having all manor of valve train issues with his 347 (same cubic inch as mine) and finally put a 6300 chip in the MSD and hasn't had any problems since. Maybe it's all my doing IDK.
If I can spin a big block 6800 countless times, that little small block should do it all day.
Old 08-06-2014, 05:59 PM
I'd say more cubes so you can make it less rowdy. A quality engine should go a season and then need maintenance, not rebuilt. I wouldn't want to give up much rpm for road racing. How tight are you spinning it?
I think I have a 7000 chip in the MSD -- but it might be less -- and I've NEVER hit the limiter. The Lotus I hit all the time - because I can't hear it with my new helmet (has communications built in and the ears are quiet as hell).
I think that motor - with it's titanium valve train - and built by a top notch builder -- should run for 4 years of track days doing nothing but adjusting the solid lifters.... So either I'm doing something to it - damned if I know what - or there's some geometry issue that isn't being caught. Thus a fresh set of eyeballs will be in order. Unless I broke it real good.... and in that case a new motor will fit the bill --- or be on my bill! LOL
Old 08-06-2014, 06:17 PM
First thing that comes to mind is the titanium valves are causing you problems. Seems overkill for a small block with a 7k chip. If it doesn't have shaft mounted rockers, that's a must. I'd say the titanium valves warrant setting the valves HOT. Who knows what happens at road racing temps. I'm just throwing things out there. Me, I'd put a less radical combo in it or let Ron go through the entire engine.
Old 08-06-2014, 06:49 PM
clill's Avatar
clill clill is offline
347 ????
Old 08-06-2014, 07:11 PM
It has shaft rockers.....
Old 08-06-2014, 07:12 PM
347 ????
I think that's what it is.... but damned if I really know.
Old 08-06-2014, 08:52 PM
craig510's Avatar
craig510 craig510 is offline
This would make a nice addition.
Old 08-06-2014, 09:03 PM
Jack Mauer says the motor is a 356 cubic inch
I seem to remember the numbers working out to be 355
Old 08-06-2014, 09:23 PM
Well, it's apparent why Charlie struck you such a sweet deal.
Old 08-06-2014, 10:08 PM
Sieg's Avatar
Sieg Sieg is offline
Previously I've heard 355, then 347.
It's a small revvie Ford with a very good power curve...........when it's running.
