View Poll Results: Which rear suspension?
DSE's Quadra Link 104 45.61%
Alstons G Bar 77 33.77%
Leave the GW Cat 5's 17 7.46%
Just pull the trigger go Lateral Dynamics 30 13.16%
Voters: 228. You may not vote on this poll
Old 11-24-2009, 10:40 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Originally Posted by ProdigyCustoms View Post
Here is a G link istall we just finished. Pretty cool stuff and a easy install. The adjustability is especially nice if you are dual purposing the car. The ride of any good four link compared to performance leafs is reason enough to run a 4 link. Tire wise, you can mini tub and run 335s with leafs or four links. But doing a mini tub leaf spring car today is a pure welcome to 1999 set up. The net cost of components difference between a mini tub G link or Quadra Link kit and a mini tub leaf spring kit is about $1500. Easily recovered in added value of the finished car.
Frank--is this at the lowest setting? It looks like it from the shocks being spun down all way---perhaps that was just the install---Just wondering if you could go lower with it.
Old 12-10-2009, 08:35 PM
tmadden's Avatar
tmadden tmadden is offline
Default Who's car?
Who does this beauty belong to? Don't see it in the members section
Old 12-10-2009, 08:43 PM
We just finished it and sent it home to California.
As for ride height, we set it up that way, customer did not want it to low. it would go lower thoough
Frank Serafine
Old 12-11-2009, 12:54 AM
dlouie87's Avatar
dlouie87 dlouie87 is offline
thats pretty under the rear
Old 12-11-2009, 10:09 AM
JP customs's Avatar
JP customs JP customs is offline
Looks great looking to do this over winter can't wait to see the ride difference from springs.
Old 12-12-2009, 09:43 PM
JRouche JRouche is offline
Looks looks a solid setup.. I like the all in one bracket. Looks stout and frees up some room for exhaust.
I was looking at it for height too. The pics of the bracket? Are they with the suspension at full droop? Was wondering cause the sway bar arm is pointed way up from the looks of it. Any more compression on the suspension looks like it will push the sway bar's arm link pretty far forward. Id prolly like to see a longer link and have the arm a lil more level with the ground. Might just be the pics giving the look that the arm is pointing up alot.
But I like the ride height of the car on the side shot, looks good.
Everything looks good. Cept Id like to see a longer sway bar end link. Looks kinda short with the arm pointed up. JR
Old 12-13-2009, 01:18 AM
deuce_454's Avatar
this thread was started on: 03-31-2008, 03:39 AM ... what did he end up going with?
Jake: Hit it.
Old 12-26-2009, 02:06 PM
81s 81s is offline
Default Pulling The Trigger???
I think at the bottom of the first page he said something like pulling the trigger. Either he offed himself or i guess went with the lateral dynamics.
Old 01-01-2010, 09:35 AM
mstennes mstennes is offline
After getting sidetraked twice, than Lateral Dynamics back log/woes, I'm going to go Speed Tech now that the Christmas bleeding of the accounts is over
Old 01-01-2010, 12:57 PM
JustinB's Avatar
JustinB JustinB is offline
good choice!
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
