Old 12-30-2010, 03:23 PM
wedged wedged is offline
butchered first generation dakota rotors. yes, they were cut on a lathe.
poser shots
Old 12-30-2010, 05:37 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Very nice. That is going to be a mean looking truck.
Old 12-31-2010, 07:06 AM
The truck already has a set of 2" drop spindles on it. I'm using the stock ones to build the front brake kit. It's mustang cobra based with 13" rotors in the front. If you go back through the thread, you can see the 11" rear rotors.
Old 01-11-2011, 12:53 PM
over the last couple of days I ordered the parts for the triangulated four link rear suspension.
I've got 4 of these coming for the axle end of the links:
There's a set of these on their way:
And also some DOM tube to make the bars and bushing sleeves for the frame end of the bars.
Old 01-22-2011, 05:13 PM
the pile of goodies. Laser cut tabs & brackets from Ballistic Fabrication, Creeper joints from Foothills Offroad and coil overs from S&W Racecars.
This bracket kit is pretty cool It is keyed to position the brackets on the bottom plate. I'll have to modify it because it maxes out at 40 degrees and I want at least 60 degrees between the bars.
This is about where the upper will sit.
After measuring the brackets, I altered my CAD drawing. It looks like I'll have an instant center at about 99.5" forward of the rear wheels. The wheel base is 116".
Old 01-22-2011, 05:59 PM
tones2SS's Avatar
Thumbs up
Very cool. Keep us posted.
Old 01-23-2011, 06:25 AM
R.A.D's Avatar
R.A.D R.A.D is offline
way to keep the blood flowing....
Old 01-29-2011, 04:49 PM
finally I was happy with CAD drawings of the frame, so I started cutting and welding.
I drew the full scale layout on the surface of the welding table and tacked the frame. Then flipped it over to tack some more.
Here's both arches side by side after tacking
I added the forward extensions. I'm leaving the rear portion for later, after the frame is welded together.
It's way off in the next to pictures, but I had to drop it in place to see what it would look like.
I did not make any cross members yet. I'm not sure where I want them.
Old 01-29-2011, 05:00 PM
It looks good.
Old 01-29-2011, 07:26 PM
tones2SS's Avatar
Thumbs up
Great build Wedged. Keep us posted.
