Originally Posted by GregWeld
Using this same logic - ya think there's a reason that Pontiac didn't use a RICHMOND?
I see you are still trying to pick a fight, and that's OK. You obviously had a bad experience with the Richmond transmission and now you are on a mission to enlighten the masses. Kudos to you.
Shifting quality can be effected by any number of things. Certainly the design of the transmission internals is important, as is the design and adjustment of the shifter. The other factors that are often overlooked are fluid type and clutch adjustment. I mentioned before that the Richmond requires a lubricant with MORE friction. This allows the synchros to have more "bite" which improves the shift quality tremendously. It is also vital that the air gap on the clutch is properly set. Any drag on the clutch disk during a shift will make the shifting feel "hard."
Every transmission has pros and cons. The weight of each pro and con is very subjective. Some people want ultimate strength. Others want shift quality. For others, a quiet transmission is most important. We are blessed to have such a great number of available transmission options on the market today. 25 years ago it was simple. Do you want a wide ratio Muncie or a close ratio Muncie? If strength was more important, then the M22 was king, but you were stuck with a 2.20 first gear.
Here are a list of pros and cons regarding the Richmond.
Pros.
Great gear selection
http://www.richmondgear.com/07pdfs/RG24.pdf
No major transmission tunnel surgery required (big issue for a-bodies)
Easy to service
Great parts availability (most parts stocked by Jegs and Summit)
Relatively light weight (especially compared to T56)
Cons
Ultimate strength (although I have yet to see a documented case of major carnage)
Shift quality (much of this is user induced due to poor lubricant selection and clutch adjustment)
Price
External shifter design (although this can be a pro when you consider the ease of adjustability compared to an internal rail design)
My point is that every product has pros and cons that must be examined in the context of the application. To make blanket statements like "All Richmond transmissions are junk," is just immature and naive.
Andrew
