Kevin and I have joined force's with Bret Voelkel and Ride Tech.We will be outfitting The MillerTime 69 Camaro w/Ride Tech's Brand new Triple ajustable Coil Over's( frt.& rear).And we will also be installing a Ride Tech 4 Bar rear suspension w/H.D. Heim Ends out Back.We would like to share to install of the rear 4 bar and Triple ajustable Coil'Over's w/you.Let me tell you,These are some great looking pcs. The shock's are 1st.Class and the 4 Bar rear suspension is very well built.We are going to try and get everything installed and fine tuned so we can show up at the GoodGuy's in DesMoines.The 4 bar came very complete w/everything needed for a quick in stall.The shock's went togather nicely.Radrambler Tom Will posting the install photo's for us.Once again A special Thank's To Bret Voelkel and The fine Folk's at Ride Tech for helping Kevin make his camaro better than it was before.
Man, this is awesome, the car should be very fast after this. Those coil overs look killer, I might have to see if I can save up enough dough to get a set for the javelin.
Thanks,
Jon
Jon,You bet those Ride Tech Coilover's are super nice.The workmanship is 1st.class,I can't amagine any other shock quite this nice.
