Old 07-10-2018, 08:18 PM
Flash68's Avatar
Flash68 Flash68 is offline
So, I'm not sure what is different but the first picture in this post is huge and the rest are prefect in size... Is it just me?
I think so.... but then again you are kinda special.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-11-2018, 07:29 AM
hackster's Avatar
hackster hackster is offline
Well ****.......you guys are right. I was trying to take the easy way out on the panhard but its not the right way.
Ill order up some brackets and chop it off when I get back home from working out of town this week.
Thanks for being jerks and calling me out.
Sean
Old 07-11-2018, 09:00 AM
ScotI ScotI is offline
Sean
Please educate the rest of us "not in the know".
I always understood the Panhard bar should be level (@ ride height) & @ axle C/L or slightly below on a street car (track only might be different).
What's the problem here?
Old 07-11-2018, 09:25 AM
SSLance's Avatar
SSLance SSLance is offline
Ahhhh.... Thanks...
Lance
Old 07-11-2018, 09:28 AM
hackster's Avatar
The panhard bar is an excellent tuning tool. Adjusting its location in relation to both the chassis and the rear axle has a direct impact on roll center and can be used to help with grip. If you have adjustability in its mounting points you can tune that rear roll center and make huge improvements in handling.
Ron Sutton has a class that he puts on that was the first real suspension design class I took, he is much better at explaining it than I will ever be.
Flat at ride height is one equation that is taken into account and probably works ok for street cars, but overall height of the panhard bar, from the ground at ride height and being able to go up or down on both ends is huge.
Dropping the axle side of the panhard bar on my F100 made a huge difference and I should know better.
Take a read through this, its an amazing intro to handling.
https://lateral-g.net/forums/showthread.php4?t=42568
Sean
Old 07-11-2018, 10:57 AM
De nada, dude! If I've got a booger on my nose, it is my hope that somebody will say so. It's the mark of a true friend (not the booger, but the mention thereof)!
Sean
Old 07-11-2018, 11:03 AM
You're right in terms of the level setting, but when you're building a car, the weight (which will change) will be something that affects ride height, along with wheel fitment and what you deem fashionable. When ride height changes (and you have a Panhard, which is like a 250-year old design, by the way), diagonal angle in the bar will be induced, and this will jack the axle one way or another (in a fixed position). That's no bueno. If you can't adjust the angle out (via vertical adjusters and the threaded heims on the bar), there will be an unmovable funk in your car's handling.
Old 07-17-2018, 11:27 PM
67goatman455 67goatman455 is offline
wow man, my buddy has a turbo LS wagon the same year so i sent this thread over to him.
1967 GTO, LS2 T56
WILWOOD FORGELINE RIDETECH
$10k Budget driver/ track car
Old 07-18-2018, 05:39 AM
MSTSFabbed MSTSFabbed is offline
Dude, I'd watch you build a bicycle if you posted a thread about it!
Always interesting, such quality work, and love the home-built, home-brewed DIY awesome!
Get some rest in there somewhere, I'm tired just from reading about all your work haha!
Stephen S.
Old 07-18-2018, 10:18 AM
I get the 'how it works' portion. I guess I interpreted the original statement incorrectly & read it as there was a serious flaw as installed. It looked functional so that's why I inquired.
I built my 64swb Chevy trucks Panhard bar frame mount as adjustable but when I did my Dually I just set it level @ ride height (full weight on the ground).
