Old 01-16-2026, 05:39 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
I've used i-Solids for 3D prints too large for me when I wanted it to be one piece. I found them on craftcloud and it was cheaper to go through them then it was through craftcloud.
https://www.i-solids.com/
Instagram- camaroaj
The Following 2 Users Say Thank You to CamaroAJ For This Useful Post:
camcojb (01-16-2026), Goosesdad (01-26-2026)
  #792
Old 01-16-2026, 06:25 AM
Goosesdad's Avatar
Goosesdad Goosesdad is offline
Thanks AJ!! Much appreciated.
Have a great day!
John
My Build Thread:
https://lateral-g.net/forums/showthread.php4?t=53320
The Following User Says Thank You to Goosesdad For This Useful Post:
  #793
Old 01-26-2026, 05:24 PM
Goosesdad's Avatar
Just some process pics here.
Needed to reattach the lower portion of the nose, hot-glued some paint sticks to anchor it in place, flat, so it can be fiberglass'd in place .
2 layers of 1 1/2oz mat laid down in the back over the cut joint.
After the above cured solid, ground out the cut joint to get down to clean glass, used a round carbide burr.
Not a great pic here, but used 1/32" glass fibers + resin to create a fiberglass paste and filled that grove that was ground out. Let it cure and then sanded flat. That's all for that now until it gets to body work.
Installed and then set up a laser level to start mounting the bumperette's.
Using a mix of some fiberglass ribs with a metal mounting bracket. Drilled some holes to create a path for the same fiberglass paste to flow through. The end result will be a combination of a chemical and mechanical (mostly) bond to anchor the metal mounting brackets. This is before the fiberglass paste, used a little hot-glue to hold the bracket in place while the glass is laid down.
This is the first step in laying down the fiberglass paste.
Have a great day!
John
My Build Thread:
The Following 4 Users Say Thank You to Goosesdad For This Useful Post:
camcojb (01-26-2026), jarhead (01-27-2026), OLDFLM (01-27-2026), WSSix (01-28-2026)
  #794
Old 01-31-2026, 07:56 PM
Goosesdad's Avatar
Hope all is well for everyone.
Bumperette mounts are complete. They are done until bodywork time.
Final sand on the lower splitter plug. Will start the mold next week.
Test fit.
Have a great day!
John
My Build Thread:
The Following 6 Users Say Thank You to Goosesdad For This Useful Post:
camcojb (01-31-2026), dhutton (02-01-2026), fleet (02-11-2026), Spiffav8 (02-12-2026), Tinker (02-01-2026), WSSix (02-02-2026)
  #795
Old 02-01-2026, 06:14 PM
syborg tt's Avatar
This front end is going to be a bad ass
marty-mj
The Following User Says Thank You to syborg tt For This Useful Post:
camcojb (02-01-2026)
  #796
Old 02-02-2026, 10:22 AM
Tinker's Avatar
Tinker Tinker is offline
Marty, I’d say front end to rear end!
Chris
The Following 2 Users Say Thank You to Tinker For This Useful Post:
camcojb (02-02-2026), jarhead (03-21-2026)
  #797
Old 02-03-2026, 05:29 PM
Goosesdad's Avatar
Thanks guys!!
Have a great day!
John
My Build Thread:
camcojb (02-04-2026)
  #798
Old 02-03-2026, 06:12 PM
Goosesdad's Avatar
Started the mold on the lower splitter.
Mold release
Gelcoat
5 Layers of 'glass, first half of the mold complete.
Have a great day!
John
My Build Thread:
camcojb (02-04-2026), Spiffav8 (02-12-2026), syborg tt (02-22-2026), WSSix (02-10-2026)
  #799
Old 02-09-2026, 07:49 PM
Goosesdad's Avatar
Needed to get some clear on the carbon interior panels so I could put them away safely, at least for a while. 4 coats of matte clear.
Need to have the AC knobs and the switches anodized so quicky fit up to pick the sheen.
Have a great day!
John
My Build Thread:
The Following 7 Users Say Thank You to Goosesdad For This Useful Post:
camcojb (02-09-2026), dhutton (02-10-2026), fleet (02-11-2026), OLDFLM (02-10-2026), Spiffav8 (02-12-2026), syborg tt (02-22-2026), Tinker (02-10-2026)
  #800
Old 02-10-2026, 12:17 PM
Goosesdad's Avatar
Forgot to mention, the lettering for the switches and AC control notations were etched with a CO2 laser and then I swept in multiple coats of paint before final wet sanding and then the matte clear. The CO2 laser gave super crisp lines in the carbon fiber/epoxy. Tried a regular laser on a test piece but it burned the epoxy.
Have a great day!
John
My Build Thread:
The Following 3 Users Say Thank You to Goosesdad For This Useful Post:
camcojb (02-10-2026), fleet (02-11-2026), syborg tt (02-22-2026)
