Old 09-08-2011, 10:41 PM
qship510 qship510 is offline
Originally Posted by Bow Tie 67 View Post
Correct me if I'm wrong, but that will not float per-see. Once the axle nut is torqued the axle shaft will become more or less rigid from the bearing into the housing, so very little camber or toe would be allowed. Unless the other end of the axle shaft has a radius to the splines.
I thought "float" referred to whether the hub is retained independantly of the axle. In Mark's case, if the axle breaks, the hub/wheel/tire stay with the car, which is a "full floater". With a stockish 9" arrangement, if the axle breaks, the axle could leave the housing, taking the wheel/hub with it. 9" is a bad example, 10/12 bolt would be a better illustration. The second case would be a "semi-floater".
I'm sure I'm missing something...
Old 09-12-2011, 09:02 AM
RENN SCHNELL RENN SCHNELL is offline
Wicked!
Old 09-12-2011, 10:28 AM
next69 next69 is offline
Mark, do you have any plans of doing a car with IRS?
Old 09-12-2011, 10:41 AM
Stielow's Avatar
Stielow Stielow is offline
Not in the near future. I have helped do the development work on a couple IRS set ups at work. There is a lot of development to get one to work correctly.
I'm happy on how the DSE 4 link works.
Mark
Old 09-12-2011, 01:18 PM
hifi875's Avatar
hifi875 hifi875 is offline
what happened to you yesterday at the lsfest??
Old 09-12-2011, 02:39 PM
cencalc6 cencalc6 is offline
Mark, what Clutch are you running?
Old 09-12-2011, 04:14 PM
Stielow's Avatar
I had a meeting at work this morning that I had to be at. It is a 9 hour tow so we left Sunday morning.
Gotta work to pay for this stuff......
Mark
Old 09-12-2011, 04:19 PM
Sales@Dutchboys's Avatar
So how are we going to make this stuff work in a Chevy II?? lol
Looks great Mark!
Paul
dutchboyshotrods.com
269-823-2967
Old 09-12-2011, 04:21 PM
Stielow's Avatar
I was running a stock LS9 clutch. I switched to a Lingenfelter LS9 clutch with a higher clamp load. I had an issue with the adjustment and the pick-up point. The clutch was draggingwhen thepeddelwas fully pushed in. Seems like I had air in the system because it was good when I unloaded it last night. Going back though the set up to verify the stack-up.
Mark
Old 09-12-2011, 04:25 PM
Stielow's Avatar
Looks great Mark!
Paul
Paul
Your Chevy II will be cool when it rolls out again with your new upgrades...
My paint still look great between all the rock chips....
I'll have to get it "tuned - up" after SEMA.
Mark
