Old 03-10-2012, 09:57 AM
Moparigno Moparigno is offline
Hi, I like your exhaust tips. Where you got it ?
Paolo from Italy:
'70 Challenger R/T 383 Hemi Orange
'70 Barracuda GC convertible 383
'65 Shelby Cobra 427 Replica
Old 03-11-2012, 04:15 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Marty, it can be ordered through improvedracing.com
Still don't know how well the pan actually works. I made only a few passes at RTTC this weekend. I figured it would be fun to keep things a little quiet, until I was there, but I swapped more than just an oil pan. My LS2 needed to be gone through, and I wanted to add more power to it. Turns out it was cheaper to buy an entire motor. I need to thank David Pozzi for letting go of Bad Penny's old 454 LS2. It dropped right in. However, I have a sneaking suspicion that something went wrong when it was being dyno'd. I'm going to figure out exactly what is wrong next week.
Moparigno, the exhaust tips are from the Mercedes parts department. They are off of an SLK, if I remember correctly...
Matt
Old 03-11-2012, 07:32 PM
syborg tt's Avatar
Thank you
454 LS2 - that is Awesome. I love that motor
Maybe version 2 of the 2nd Chance Camaro will get that motor.
marty-mj
Old 03-11-2012, 08:19 PM
Bryan O's Avatar
Bryan O Bryan O is offline
^^^And I never got my hush money.
Bryan
Project Alchemy
https://lateral-g.net/forums/showthread.php4?t=29820
Old 03-11-2012, 10:16 PM
Matt@BOS's Avatar
Thank you
Marty, it is entirely possible that in the time that it takes you to get the 2nd Chance Camaro on the road, you might have the opportunity to by a newer one of Penny's engines - and I'm not making a jab at you based on how long the last project took. If the second chance Camaro took that long you'd probably get Penny's old flux capacitor
Bryan, sorry but the hush money I had stashed away for you will probably be going towards a new head gasket, and whatever else carnage I will be looking at once it gets torn down. I'm hoping for the best, (but the coolant, of which there is a noticeable amount missing) appears to have some oil in it. It spit a bit of white smoke when I picked it up from the dyno shop, and got up between 210-230 on my way back home from RTTC. I'm guessing that when the radiator cap blew off on the dyno, it was because of the blown head gasket. I'm certainly no mechanic, so hopefully I'm wrong...
Matt
Old 03-12-2012, 12:56 PM
syborg tt's Avatar
Matt
Dude that hurt
marty-mj
Old 03-12-2012, 01:55 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Sucks to hear about your motor problems Matt :/
Good luck with an easy diagnoses.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 03-12-2012, 07:41 PM
Matt@BOS's Avatar
Thanks Chad!
Had the guys down the street at JR Competition do a leak down test on the car. Cylinders 5,7 and 8 are all pushing air into my coolant. Needless to say, I'm pretty upset. Re-sleeved blocks should be brought up to temperature and then need to have the head bolts re-torqued, so long as you're using ARP bolts, for example, and not torque to yield factory ones. This is expressly stated by Steve Demirjian of Race Engine Development who re-sleeved the block for Steve Rupp. Between Dick and I we must have asked the shop that dyno'd the car to be sure to re-torque the head bolts half a dozen times. The last time Dick asked, they said they checked a bunch of them and they were tight. What the hell does that mean??? I wouldn't be so upset, except for the fact that in this scenario it is hard to imagine the head gaskets failing for any other reason...
Good news is that it doesn't look like I have water in my oil.
Matt
Old 03-12-2012, 08:40 PM
Ron in SoCal's Avatar
Thanks Chad!
Matt
FCUK...!!! You know how I feel about that Matt. Remember all the smoke at the gas station? How wierd was that?
Hope the repair goes quick Bro. At his point I'd check everything. JR knows what he's doing...
Ron in SoCal
69 Camaro in progress
Old 03-12-2012, 10:15 PM
KPC67's Avatar
KPC67 KPC67 is offline
Not cool Matt. I hope it gets resolved without too much hassle. This just makes me even more nervous about finding a quality shop to work on my 454.
Let us know how you make out.
Kevin Carter
