Old 03-16-2012, 05:19 AM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
I've got that same transmission in my Mustang. Everytime I jack that car up with the car in gear, and I can spin the tire a 1/4 of a turn back and forth, I think of how hard autoxing must be on those parts, and how the constant on and off of the throttle must stress the gears.
Apparently they are not indestructable, if you don't mind me asking Brian did it give any warning?, or just go into self destruct. I know its hard to tell with those transmissions because they are so noisey anyway. I have heard they are freshen it regularly whether it needs it or not parts. Love the car, good luck getting it back together. Ron
Old 03-16-2012, 09:39 AM
73CPCAMARO's Avatar
73CPCAMARO 73CPCAMARO is offline
Ron,
I had no warning at all. I was going from 2nd to 3rd gear on the speed stop squared event when it let go. It was loud and ugly. Before it let go on Friday, it was working perfect. The GForce has less than one year on it. I shipped the transmission to Competition Transmissions and Gears in North Carolina. I am going to have them put the strongest gears possible in it.
Brian
Brian Hobaugh
1965 Corvette
1973 Camaro
2003 Z06
Old 03-16-2012, 10:03 AM
68protouring454's Avatar
Thats too bad brian, they usually stand up very well. I have a g force t101 thats was good all race year long, last year. If you know anybody i have a freshly built jericho close ratio built but competition tranny and gear in nc.
2.36,1.49,1.17, 1.00.
jake
Jake's Rod Shop
Old 03-17-2012, 01:53 PM
TLWiltman TLWiltman is offline
I remember reading somewhere that it's actually best to use drag race gears in an application like that. The rationale was that drag race gears are slightly softer and had better luck in dealing with the torque reversals and shock loads inherent in street driving. Not sure of the accuracy of that info, but it would be a question worth asking going forward.
Old 03-17-2012, 02:46 PM
73CPCAMARO's Avatar
The gears I had were not the road racing gears. Since that did not work for me, I am going to the road race gears. I am also changing the ratios to better fit the road courses.
Brian Hobaugh
1965 Corvette
1973 Camaro
2003 Z06
Old 03-17-2012, 04:32 PM
57hemicuda's Avatar
If you don't mind me asking, what are you changing from, and to. I'm running a 2.89 first with a 3.54 rear. I'm now changing the rear to a 3.18 to try and see if I can run the whole autox course in first gear, and make the car cruise alittle better with no overdrive.
Old 03-17-2012, 08:11 PM
73CPCAMARO's Avatar
I have a 3:70 rear. I am going from a 2.5 to 2.4 1st, 2 to 1.7 2nd, and 1.5 to 1.3 3rd.
I need a slightly taller 2nd gear and close the gap from 3rd to 4th gear for the road course. I really liked my 1.5 3rd gear, but it was a too far from 4th gear. I wish I got the 5 speed to start, but too much money for me.
Brian Hobaugh
1965 Corvette
1973 Camaro
2003 Z06
Old 03-18-2012, 01:04 AM
That sucks! I'll be keeping that in mind going forward as well.
Old 03-18-2012, 01:12 AM
Flash68's Avatar
Flash68 Flash68 is offline
That sounds like a much better spread in ratios, Brian. I didn't think you'd be liking those splits when you posted them before... but I guess the new ratios will be a benefit of this bad situation for you.
Does your trans have an internal cooling pump?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 03-18-2012, 05:30 AM
57hemicuda's Avatar
Yeah those 5 speeds are stupid money, can't really justify that. At first I was thinking the same ratios as you. Due to the lack of overdrive I'm trying to go at it from the other end. I'm 2.87/1.81/1.31/1, on the road course all I use is 3rd and 4th anyway, and I do like that spread. I think you'll be happy with the 1.30 third. My problem is autoxing, first is too low, and second is too high for my cams power band. That is why I'm putting the 3.18 rear gear in. The change will probably kick the crap out of my drag race times though.
Still can't beleive nobody has come out with a reasonably priced five speed, with some normal ratios, that will hold up. I'm sure you experienced the same thing Vinny and I did on the cruises with no O/D. Everyone else is cruising 80mph, my car really had its tongue hanging out taching 4K, Vin and I fell way at the back to the back of that pack.
If you think about it, it truely is harder then you think to build a car that can do everything well. There really has to be alot of compromise, it seems if it is a good 1/4 mile car, it won't autox, etc. etc. Its been fun, and expensive trying to figure it out. Good luck. Ron
