Old 05-16-2021, 07:06 AM
dhutton dhutton is offline
Why aren't you driving Hellfire?
Better yet where is the Riviera?
Don
Old 05-18-2021, 09:09 PM
clill's Avatar
clill clill is offline
Old 05-19-2021, 07:58 AM
clill's Avatar
Old 05-20-2021, 06:42 AM
Stielow's Avatar
Stielow Stielow is offline
https://digital.allchevyperformance....-and-greatest/
Stielow Engineering
Old 05-20-2021, 09:00 AM
garage_engineer's Avatar
garage_engineer garage_engineer is offline
Great article Mark and another great build. I'm sure you get this all the time but the quality and attention to detail of your builds in a huge inspiration to me. As an engineer myself I can appreciate the effort and time it takes to make a classic car perform the way yours do. I also try to echo your strategy of using as many OEM, factory tested parts in my build as I know how much testing goes into developing them! I'm up in New England but hope to see one of your builds in person one day!
Old 05-20-2021, 10:54 AM
bdahlg68's Avatar
bdahlg68 bdahlg68 is offline
Great article! How are the QA1's so far?
Brian
1968 Pontiac Firebird
1989 Ford Mustang
Old 05-20-2021, 02:46 PM
srode1 srode1 is offline
Installing a C&R Racing Rad.
Trying a new mounting strategy after failing a couple.
Looking at the two inlet/outlet holes on the DS of the radiator, can i assume you ditched the stock oil cooler due to clearance issues and are running the engine oil through the radiator for cooling?
Old 05-24-2021, 08:23 AM
Stielow's Avatar
Correct, we removed the factory LT5 oil cooler and used the one in the C&R Racing radiator.
Stielow Engineering
Old 05-24-2021, 11:39 AM
cpd004's Avatar
cpd004 cpd004 is offline
Originally Posted by Beechy View Post
OEMs have a"dead man" in a fuel tank......basically an inverted pie tin with a pinhole in the top surface.
When you thought you'd filled the tank, air is still trapped in the pie dish void and the fuel nozzle cuts out. The pinhole allows controlled venting to occur, so that when the fuel increases in temperature and volume (now that it's out of the ground), it swells into that void and doesn't puke out the vent lines.
THATS WHY YOU DON'T TOP OFF AFTER THE FIRST CLICK.
TOOmuch vent chamber gives the liquid/air time to settle out and is a great feature........but can't cope with massive west-coast changes in temp out of the ground vs. cooking in 95* ambient.
Aftermarket tanks don't have this feature.
Competing claims to the largest volume compared to the competition?
Carl?
I'm sure it may be still early to tell, but we've had a few 80+ degree days, so wondering how the fuel tank system is working out as far as smell/expansion, etc.?
1971 Firebird
2017 SS
Old 05-24-2021, 12:26 PM
EVIL SS EVIL SS is offline
Mark, what is this?
