Old 03-18-2018, 05:15 AM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
Messing with silicone bronze to attach my little windows, never used it before, so we will see. "AND", if you are going to bust my balls for grammar, you may want subscribe over at Corner Carvers instead of hear. That's how they roll over there, more of a book club!!
Ron Schwarz
Old 03-18-2018, 09:45 AM
gofastwclass gofastwclass is offline
I'm curious how the silicon bronze works out for you, I'm told it is perfect for stuff like that. I bought some but I haven't had a chance to use it yet.
I build my own junk...
Old 03-19-2018, 11:10 AM
FETorino's Avatar
FETorino FETorino is offline
Are you using your TIG machine for the silicone bronze or MIG brazing it?
Rob in SoCal
Old 03-19-2018, 02:02 PM
57hemicuda's Avatar
I thought I was going to tig it, because I had never heard of silicone bronze mig wire. I You Tubed silicone bronze because I have never used it before, apparently in Europe migging bronze is a very common method for installing body panels. Everything I saw on You Tube was from Britain, and none of my weld suppliers had ever heard of bronze mig wire. I did get some off of Amazon, and will try it. I will be surprised if it works the way I want, but here's hoping.
Ron Schwarz
Old 03-19-2018, 02:38 PM
Blake Foster's Avatar
It makes welding tin to tube pretty easy. you will need to run a long 3/4 stitch about 1.5 to 2" apart. i am not sure how the Mig will work but we use it a bit with the tig.
Blake Foster
www.speedtechperformance.com
Old 03-19-2018, 04:56 PM
ur-n-8 ur-n-8 is offline
Autobody shops are all buying dedicated silicon bronze mig welders for fixing the newer cars, but I have yet to see one in action.
Old 03-19-2018, 06:25 PM
57hemicuda's Avatar
I heard all you have to do is run straight Arogon, but I will let you know when I try it. Wire showed up today
Ron Schwarz
Old 03-19-2018, 06:46 PM
FETorino's Avatar
Where did you source the wire? What guage? Is there anything special you need to do with the feed on the machine with the softer wire?
Rob in SoCal
Old 03-19-2018, 07:16 PM
57hemicuda's Avatar
I got a roll of 023. and a roll of .030, I know when you try to run aluminum wire though a mig machine it sucks, unless you have a push pull machine or a spool gun. I'm hoping the bronze pushes OK, I'll let you know as soon as I try it. Have a couple more days of tinning to do before I make sparks. Wire came from Amazon
Ron Schwarz
Old 03-20-2018, 03:44 AM
dhutton dhutton is offline
I’ve used silicon bronze wire in my MIG. Works fine.
Don
