Yes, I'm a dumbass. Just wanted to throw that out there first...
So, I caught the car on fire! And didn't even know it. I was almost finished welding the holes in the inner fender a couple nights ago right when the wife got home from work. So I finished the last couple, took off my helmet & gloves, turned off the welder & gas, shut off the radio and went inside to have dinner.
Came out a couple hours later to a garage full of smoke. One of the last welds must have slowly started the towel on fire. It burned the whole thing. Luckily there wasnt anything flammable but the towel in the immediate area. And it looks as though the only real casualties are the control arm bushings, ball joint boot and a caliper slider boot. Could have been a lot worse.
So, a few parts, some refinish work, and a welding blanket later I'll be all set. And BTW, oven cleaner works awesome for fire damage cleanup!
Used the fire as an excuse to buy tall upper ball joints. And got new pivots from SPC to get it all back together during my second sheet metal mockup. Those new door skins have moved everything around... I'm waiting for a body guy buddy to come over and give a little guidance. I'm still not happy with all the gaps yet.
Picked up some button head bolts for the inner fenders to give just a little bit more tire clearance just in case. Every little bit helps right? And I dont think I've ever posted pics of the ugly fab work for the inner fenders for the extra tuckage. So here they are.
Also figured out my mounting for the Aerocatch pins. By moving the fender brace under the header panel now it clears the hood and the Aerocatch assembly, and gives me a solid place to weld on a tab for the pin and adjust height.
