Old 01-30-2011, 02:30 PM
R.A.D's Avatar
R.A.D R.A.D is offline
yes its looking great. looking forward to the updates
Old 02-12-2011, 04:32 AM
wedged wedged is offline
The bushing kits for the frame end of the the four link bars arrived. I got them from Suicide Doors which is now Quality Air Ride. The outter sleeves are very nicely made, they appear to have been cut on a lathe.
Old 03-21-2011, 12:47 PM
made a bit of progress on the rear suspension. The angle of seperation between the upper link will be 45 degrees. I can't get more than that unless I make the upper links really short. I need to make some sort of bridge for the upper links on the housing. The lower links are about 23" c-c.
Old 04-04-2011, 11:44 AM
Here's the four link with most of the bracketry tacked in place. after i took these pics, I pulled it all apart. I've got a whole lot of welding to do now .
Old 04-04-2011, 12:04 PM
It looks good, coming togther nice.
Old 04-04-2011, 01:43 PM
Sorry - but I think your angles are far too steep going to the center like that with the top bars.
Old 04-04-2011, 03:14 PM
the wide angle pictures make the angle of the upper link look steeper than it is. Link angles and lengths were determined by my CAD drawings. I also checked anti squat based on estimations of CG and it should be close to 100%, if not more. The lower bars are parallel to the ground and the included angle at the upper rear link is 70 degrees.
Old 04-06-2011, 06:44 PM
Tincup's Avatar
Tincup Tincup is offline
I just went through your thread, and I love the build. If you want to match your "Patina" go to a craft store like Michaels, the sell a paint that has a high iron content, and a chemicle that will turn it to rust.
Old 04-07-2011, 10:07 AM
I've already figured out a way to very quickly create rust with a few common household items. it works well with metal filings (almost too well, it created an exothermic reaction ), but i have not tried it on any sheet metal yet. There are a few places on the cab that i need to patch to prevent water leaks and I might try treating those areas after I patch them. There a whole lot of those paints available in all sorts of colors and that would be an option if i'm not happy with my results.
Old 04-09-2011, 03:59 PM
I welded the front half of the frame to the back half and mocked up the bed & cab again. I need to gusset where the frames connect to get rid of the flex that it has now.
This shot shows the angle of the upper links better
