Thanks Buddy! From your posts it seems to be that your a big CUDA fan also! Trust me I wont let you down with this one! You may just have to give me 10 years to do it haha
Gant MacLellan
Cuda
C6 Suspension
Another new parts update! 60mm roller cam core, another set of engine block off plates so that when I start smoothing the sand casting and blasting I can keep the engine clean and don't have to damage the Evernham plates I already have!
Clevite coated rod bearings, Clevite coated main bearings, another set of billet oil sprayers so now Ill have two sets. New Damper ring and o ring rebuild,
Front cam seal, Front crank seal, rear crank split seal cometic, Valve train Organizing tray, New 60mm roller cam bearings. Brand mew R5 MSD Pro Billet Distributor Dual Pickup.
Gant MacLellan
Cuda
C6 Suspension
Hey guys wanted to update you on my father's Tube chassis Duster drag car! His R3 440 stroker is finally built and made 780hp on the dyno on gas. Hes hoping to creep into the 800s with alcohol. Should be a wild ride and my first attempt at a drag car!
Gant MacLellan
Cuda
C6 Suspension
Hey guys I already sold one pan, I have two left in the for sale section! Wanted to post up better pics of the quality of these for you to admire! Updates soon!
Gant MacLellan
Cuda
C6 Suspension
