Old 08-16-2013, 07:47 AM
parsonsj parsonsj is offline
The AC-Delco pn is 15-80803 if that means anything.
John Parsons
Old 08-18-2013, 08:33 PM
I talked with a local tech today who does a lot of late model upgrades. He said that on C6s they routinely swap to dual Spal fans and get another fan controller and split the signal line from the ECM with great results.
So it seems a single controller with dual fans and dual controllers splitting the signal both work fine.
John Parsons
Old 08-19-2013, 08:55 AM
samckitt's Avatar
samckitt samckitt is offline
Originally Posted by parsonsj View Post
I have found this site.
http://www.obd2allinone.com/sc/details.asp?item=m5j3
Looks like you can pick up the connectors there. 10 / $2.95.
Here is another site to get the terminals from:
http://www.eficonnection.com/eficonn...spx?ItemId=314
Downside is you have to have a $25 minimum order.
Scot
86 Monte SS
LS2/T56 Magnum
Old 08-19-2013, 02:03 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
mouser.com also has the ecm terminals. A lot of sites call them Delphi connectors but they are really molex. The molex pn is 33467-0005 minimum quantity 1.
http://www.mouser.com/ProductDetail/...TgQDO3tTBTM%3d
Jason Mitchell
1971 Camaro 416 LT1 Project
Old 08-19-2013, 02:10 PM
Excellent! Can you find the cavity plugs? I just spent 5 minutes on Mouser without any luck...
John Parsons
Old 08-19-2013, 02:30 PM
JMitch19's Avatar
Most of the the work that I have done has been will GM's E38 ecm. Below are the two connectors for the E38. They don't seem to list a cavity plug at all. I have completely stripped a few factory GM harnesses any I've never seen a cavity plug in a factory setup either. There is a build in seal in the connector that seals around the wire when you insert it. The wire openings in this seal are very small. You could just cut up some scrap 20/22 gauge wire and insert it in the unused spots.
http://www.molex.com/molex/products/...P_HOUSINGS.xml
http://www.molex.com/molex/products/...xml#partdetail
Jason Mitchell
Old 08-19-2013, 02:40 PM
No, there's a cavity plug in the harness. They look like this:
John Parsons
Old 08-19-2013, 03:15 PM
JMitch19's Avatar
Looks like I just needed to work a little harder... http://www.mouser.com/ProductDetail/...ff%2fQDg%3d%3d
I have a completely stock GM L92 harness sitting right next to me which has no factory cavity plugs. It's good to know these are available.
Jason Mitchell
Old 08-19-2013, 03:17 PM
Awesomeness! Thanks very much. I'll ordering up some tonight.
John Parsons
Old 08-19-2013, 07:22 PM
samckitt's Avatar
Pretty sure this is one of the connectors, but I think it is the one that goes to the fan, not the fan module itself.
http://www.casperselectronics.com/st...2fb0a1b1b04209
http://www.eficonnection.com/eficonn...spx?ItemId=915
Scot
86 Monte SS
LS2/T56 Magnum
