Old 05-26-2015, 05:35 PM
So glad to hear you're enjoying the car. It's a sweet build. Good luck with the upgrades!
Old 05-27-2015, 08:27 AM
DavidBoren DavidBoren is offline
I bet that will sound superb when all hooked up. The Spintechs really do line up with the other ones, should be an easy enough swap. Can't wait to hear that thing.
Old 05-28-2015, 08:02 AM
Frankenstine's Avatar
Frankenstine Frankenstine is offline
Default Congrats
Congrats Neil, hope you will do a walk around Vid with this beast running with the Spin Tech's or a drive by Vid ?
Old 06-01-2015, 09:50 PM
Neil B Neil B is offline
Will do. Still waitin' on parts and I'm out of town for work for until mid-June.
Old 07-12-2015, 07:23 PM
I finally got the 3" exhaust system bolted up today. The fit of the system is excellent and was a 100% bolt-on effort. No cutting, no drilling, no welding. All I did was dress the ends of the pipes and expand a few of the joints a bit. It basically fell into place. I still need to take a drive and final align the clamps. I'm still debating whether or not to put a 45 degree cut on the tailpipe exit. Nice work Hooker!
Old 07-13-2015, 09:15 AM
Ron in SoCal's Avatar
Yes, 45s I think Neil. Also, we need a sound clip with those spintechs and 3 inchers!
Edit: what are those bushings?
Ron in SoCal
69 Camaro in progress
Old 07-13-2015, 09:47 AM
Sound clips to follow! The bushings are the Hooker-supplied tailpipe hangers/isolators. Everything bolts up to existing holes which was a requirement for my build.
Old 07-13-2015, 09:54 AM
Flash68's Avatar
Flash68 Flash68 is offline
Spintech is a great choice for that engine Neil. Can't wait to hear it sing.
And for your car and theme I would leave the tips as is. Looks great.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-13-2015, 09:58 AM
Ahh, roger that. Subframe connectors in your future or did I miss them?
Ron in SoCal
Old 07-13-2015, 10:25 AM
I've agonized over this. I really, really don't want to drill or weld on the car. I don't plan to launch the car or put sticky tires on it, but some type of additional structure under there sure would be nice. I've seen some cars start to crack where the rear quarter meets the roof at the corner of the side window, and I don't want this to happen on mine.
