Old 08-28-2015, 04:31 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Originally Posted by dhutton View Post
How much gas did you put in the tank? I would recommend at least 5 gallons. If the pump is mounted high it may cause you problems. Most run in tank pumps....
Don
And externals need to be mounted below the tank to gravity feed. The pumps are pushers not suckers
Old 08-28-2015, 05:38 PM
Swain's Avatar
Swain Swain is offline
Lowered the fuel pump got it to run for a sec then back fires think the valves are maybe too tight
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 08-28-2015, 06:15 PM
Should have the mods change subject just to avoid any wirdness for psi conversion s
Old 08-28-2015, 06:56 PM
Che70velle's Avatar
Jay, did you have the engine apart? Maybe a cam change? I've seen many people put too much preload on the lifters of a SBC, and it will back fire and not run every time, but I'm not sure it's possible to accomplish this with an LS platform, to that extent...having said that...you said earlier in the thread that you weren't getting spark. Can you verify spark and fuel?
Thanks Dad!!
Old 08-28-2015, 08:40 PM
Vega$69's Avatar
Ls3 rockers are not adjustable. If a cam swap was done then measuring pushrod for proper length would be the prudent thing to do.
These are hydraulic rollers so unless they are way off it would not keep the motor from running
I'm trying
may just have to roll down to Cali
Old 08-28-2015, 09:24 PM
Swain's Avatar
Ya that's true. Cam was never taken out. It's a crate engine with the 480 cam
I'll get back on it tomorrow.
Thanks for all the helpful hints
Jason Swain
Old 08-29-2015, 12:30 PM
Swain's Avatar
Car starts up found out why the car backfires. The rockers were off the valves all he way on a few cylinders.
Think we got it figured out
Jason Swain
Old 08-29-2015, 11:35 PM
Vince@Meanstreets's Avatar
Dang, Hecho en where?
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 08-30-2015, 11:21 AM
Swain's Avatar
Two rocker arms have bad bearing so in going to buy a new set and replace them all.
Anyone run roller rockers? Or should I stay with the stock style rocker arms with the Trunion kit?
Jason Swain
Old 08-30-2015, 11:31 AM
http://ls1tech.com/forums/generation...ones-best.html
