Closed Thread
Old 07-12-2006, 03:57 PM
Reckley's Avatar
Reckley Reckley is offline
I'm with you Stuart. I blew about $60 in junk food over the GG Columbus weekend.
  #82
Old 07-12-2006, 07:08 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Talking
If you are like myself and want a rack on your sub (because you just like racks), quoted by Murtah...
I like racks, big racks.
Jim
  #83
Old 07-12-2006, 07:14 PM
victionone victionone is offline
DSE has suspension geometry numbers on their website. I'm still curious on weight tho...
http://www.detroitspeed.com/Product%...s/subframe.htm
Anyone here know what they are looking at?
  #84
Old 07-12-2006, 09:52 PM
Steve1968LS2's Avatar
DSE SUBFRAME SPECIFICATIONS
NOMINAL CAMBER
- 0.5°
NOMINAL CASTER
+ 4.5° (ADJUSTABLE TO 5.5°)
TOTAL SUSPENSION TRAVEL
4.0"
TOTAL BUMPSTEER, 30" TOE-SPAN
0.070" OVER 4" OF TRAVEL
TURNING ANGLE ( 18"x10" OR 17"x9" WHEELS )
30.0°
ACKERMAN ANGLE ( 18"x10" OR 17"x9" WHEELS )
2.5°
TURNING ANGLE ( 18"x9" WHEELS )
33.8°
ACKERMAN ANGLE ( 18"x9" WHEELS )
3.5°
Ok, time for the experts to sort that out
  #85
Old 07-12-2006, 11:37 PM
murtah's Avatar
murtah murtah is offline
Did anyone mention what trans x-member the sub is drilled for in the pictures? Sort of looks like ATS. Obviously they give you the option of using anything a stock frame could use, I was just wondering who they had in mind with those pre-drilled holes.
I wonder if a LSX motor with the a/c compressor in it's stock location would work? I never did like mounting it up high.
  #86
Old 07-13-2006, 05:32 AM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
Well....I know that 18" x 10" means an 18" Diameter by 10" wide wheel
Lead.
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
  #87
Old 07-13-2006, 08:33 AM
4mm 4mm is offline
I called and asked Stacy, she said they never tested for that and they could not give a definite answer. They tested an LSx with the Vintage Air bracket setup. I would be better for me if it fit in the stock location, I prefer to use stock brackets at their stock location.
  #88
Old 07-13-2006, 08:38 AM
It was designed after factory. So is our mounting brackets, which is why it looks similar. Our T56 crossmember will bolt right up to that frame.
Tyler
  #89
Old 07-13-2006, 05:33 PM
murtah's Avatar
Tyler,
I was checking out your new site yesterday, A lot better than the old one. Will your NEW t-56 crossmember work on the DSE sub? it seems it has more clearance (that your older one) for exhaust and I like the adjustability. I couldn't tell because my piece o' sh*t government computer wouldn't let me open the pdf file.
  #90
Old 07-13-2006, 05:45 PM
Yes, it should bolt right up to the DSE frame. The adjustablility is designed for the different T56 variants, and engine combos. Load the .pdf when you get home to see it up close.
Tyler
Closed Thread
