Old 01-20-2020, 06:34 PM
RT_66_Pro_Touring RT_66_Pro_Touring is offline
Last summer during our "off season" I made some significant changes to Barney, adding EFI to the SBC under the hood and making big changes to the rear suspension spring and bar rates. Both changes were meant to make the car not only more competitive on track, but also to make it more street friendly off the track.
If I have been tracking your progression right, you were running a significantly stiffer than stock rear spring with a light rear bar. What did you change and why?
Old 01-20-2020, 09:20 PM
SSLance's Avatar
SSLance SSLance is offline
I ran 600# rear springs and no bar for several years. I went back to 250# rear springs and a fairly light rear bar over the summer on an effort to get more forward grip.
Especially at GGs style first gear courses, the car just spun the rear tires too much.
It now hooks up much better making for faster times and better tire life but I did have to adjust my driving to the loss of lateral grip.
Lance
Old 01-23-2020, 08:39 PM
Hmmmm. That's counter intuitive to me, softening the rear to get more front bite. Sounds like you lost overall bite and gained rear traction.
Old 01-23-2020, 09:37 PM
SSLance's Avatar
The front lateral grip is still very good, the rear lateral grip is where I gave a little bit on in certain situations. The forward bite increase more than makes up for it though.
Lance
The Following User Says Thank You to SSLance For This Useful Post:
Che70velle (01-24-2020)
  #975
Old 01-24-2020, 06:37 AM
Gscherer78ta's Avatar
Gscherer78ta Gscherer78ta is offline
Softening the rear will allow the weight to transfer to the front when lifting or when the brake is applied, putting more weight over the front tires. Can also have this same effect by decreasing the rebound on the rear shocks.
Greg
'78 Trans Am - Y88-R LS3/T56,
Holley EFI, UMI Performance
Old 01-27-2020, 02:31 PM
SSLance's Avatar
Had to add data to this run from Sunday at Marana just to see for myself.
I'm particularly pleased with the cars ability to transition back and forth 1G to 1G several times in a row in a 45-50 mph slalom without breaking a sweat or sliding a tire. We had two drivers running back to back in back to back run groups, so 16 runs total in a little about 2 and a half hours time. We sprayed the right rear and right front tire once to cool them down after the 12th run is all. Other than that just turn the key and go. Still haven't touched a screw or a knob since last October.
Pretty happy camper...
Here are some cool pics from the event as well.
Way more great pics from Amanda Hitt here... https://adventurewife.smugmug.com/20...SCCA/i-QF7TkGR
Lance
The Following 2 Users Say Thank You to SSLance For This Useful Post:
rixtrix1 (02-01-2020), Sonar Chief (02-11-2020)
  #977
Old 02-11-2020, 04:05 PM
SSLance's Avatar
Finally got around to adding that safety item that I hope I never have to use. On board fire system...
Here you can see the manual pull T-handle and the driver nozzle.
Here is the engine nozzle
I didn't grab a pic of the third nozzle that sticks through the trunk floor and points at the fuel pump and fuel lines on top of the fuel tank.
I also finally put a pretty good bend up on the throttle pedal to make it easier to get 100% throttle, probably raised it an inch off the floor.
Now I'm all ready for two days of on track action at Arizona Motorsports Park Feb 22-23. Skipping the SCCA Autocross this weekend to save my tires for the track weekend.
Lance
Old 02-11-2020, 06:52 PM
Sonar Chief's Avatar
Smile
Lance, looks good! Did you get an automatic system or just a manual system?
Been looking at Safecraft systems also, and by the way ... please make sure ALL firewall pass-throughs are sealed. That pic w the wire loom looks suspiciously loose, FYI.
Michael
Old 02-12-2020, 07:41 AM
SSLance's Avatar
Thanks Michael. It's a 10# 3 nozzle manual system.
Lance
Old 02-12-2020, 07:21 PM
The event pics were great. That 70 Chevelle looks so good even with that pole accident in the drive's side.
Glad the car is working well for you, Lance!
