Old 04-10-2005, 08:49 PM
Nutsy Nutsy is offline
Default Twin Turbo 2nd Gen
Hey guys,
I know this isn't a PT car, however, there is some good technical articles on a TT SBC buildup and stuff.
http://www.grapeaperacing.com/GrapeA...maro/index.cfm
Trev
PS: I am not affiliated with this at all, i just came across this site.
Old 04-10-2005, 10:13 PM
camcojb camcojb is offline
Yep, awesome car, great guy. Didn't break the bank on the motor either.
Old 05-03-2005, 03:49 PM
70ptta 70ptta is offline
is there any other 2nd twin turbo gens out there that are done or almost done
Old 05-05-2005, 06:05 PM
david@ronsraceshop's Avatar
david@ronsraceshop david@ronsraceshop is offline
Well I was thinking of building a twin turbo set up using Gale Banks system but I think if I'm going to do some thing like this I'll be using a ATI Pro Charger in place of the 2 turbos.
only because of the total cost when done
David@RonsRaceShop
VP RonsRaceShop
1971 RS Camaro
SBC 396 cid .... Comming Soon
ATS Spindles ..... Comming soon
14" Corvette Brakes with 6 piston Calipers ... Comming Soon
Tremec TKO-600
ROH 18x8 Front Toyo Proxes T1s
ROH 18x10 Front Toyo Proxes T1s
100-0 .... 185ft
60-0 ...... 110ft
13.40 1/4 mile
109 MPH 1/4 mile
Old 05-05-2005, 06:41 PM
RPO1LE RPO1LE is offline
I'd like to see more Gen 2 Camaro projects as well.
In regards to turbo charging & super charging, what are the pros and cons?(outside of the norm). I'm on a tight budget myself but I would like to give either a try. Also, does anyone have any previous experience(s) with tuned port injection? I know there's limits to what you can expect out it but I'm not looking to set any world records.
Rob
Old 05-05-2005, 08:35 PM
spaztikatik spaztikatik is offline
well, as far as the comparison between turbo charging and supercharging, its pretty simple. The supercharger uses power from the engine to make more power, but you dont gain the power that the supercharger uses. Turbos don't use anything but exhaust gases and act as a compacting windmill. I'd go with turbo's if they're in your budget, just because they're damn cool and don't use as much power, however they do tend to take up a bit more space under the hood if you run twin turbos. a single turbocharger might make decent power for you, stay in budget and keep real estate under the hood clear. A well developed system will virtually eliminate turbo lag too. I know there's a person or two from Banks drifting around here somewhere, you might want to get in contact with them if you'd like some advice, they seem to be extremely knowledgable guys (considering this is their job).
As for the TPI system and its capabilities, I don't have too much knowledge on this YET, so I'll leave it to the other guys to chime in
good luck and hope this all helps!
Russ
