Old 09-16-2020, 10:46 AM
Jr's Avatar
Jr Jr is offline
Default LS fuel pressure/transducer mount
Hi guys,
Has anyone come up with a creative way to mount the fuel pressure switch/transducer? I’m using the LS9 or CTS-V fuel rail. Please post your pics.
Old 09-16-2020, 09:17 PM
andrewb70's Avatar
Originally Posted by Jr View Post
Hi guys,
I would keep the transducer off the rails and off the engine. Ou can run a AN-4 off the Schaeder valve and a hose and remote mount the transducer. There are also other options depending on how you have the read of the fuel system plumbed.
Andrew
Instagram @projectgattago
I deliver what EFI promises.
My YouTube Channel
The Following 2 Users Say Thank You to andrewb70 For This Useful Post:
camcojb (09-16-2020), pannetron (10-21-2020)
Old 09-17-2020, 07:51 AM
protour's Avatar
protour protour is offline
What fuel regulator are you using? If its an aeromotive type, just T the gauge and put a sensor there.
72 Chevelle. 370ci LS, Forced inductions S476, SpeedTech Suspension equipped, C6 Z06 brakes
Old 09-17-2020, 10:26 AM
Jr's Avatar
Jr Jr is offline
Andrew
I remember seeing your video with the cracked schrader valve. My plan is to do just what you said, but I’m looking for a good location to remote mount it...
Old 09-17-2020, 10:29 AM
Jr's Avatar
Jr Jr is offline
The entire fuel system Is complete already. I didn’t add this transducer to the Holley because I didn’t think about it at the time. I have a ricks tank and vaporworxs controller.
Old 09-17-2020, 12:59 PM
protour's Avatar
So wheres the fuel regulator or what style of regulator is being used? Assuming you are either running an intank regulator or sorts or a filter/regulator combo deal then?
Old 09-17-2020, 10:14 PM
andrewb70's Avatar
There is no regulator. The VaporWorxs setup is a PWM controlled closed loop fuel pressure system.
Andrew
My YouTube Channel
Old 09-18-2020, 10:40 AM
protour's Avatar
Andrew
Ahh ok thats where I was going with this. Kinda hard to help without knowing these things so I was throwing darts blindfolded and also missed the vaporworx controller part.
Old 09-20-2020, 01:56 AM
CarlC CarlC is offline
If an AN6==> GM 3/8 quick connect fitting is used on the fuel rail line attachment one of these may help:
https://www.vaporworx.com/shop/produ...8-npt-on-side/
http:www.vaporworx.com
The Following 2 Users Say Thank You to CarlC For This Useful Post:
camcojb (09-20-2020), pannetron (10-21-2020)
Old 09-20-2020, 02:48 PM
Jr's Avatar
Jr Jr is offline
Carl,
If I’ll call you on Monday.
