Old 04-29-2022, 09:01 AM
garickman garickman is offline
Originally Posted by Jimbo1367 View Post
I like the hood adjusters on the truck. Slick idea but how do you plan for rain runoff? Do you plan on a drain tube? If you would off left a lip or seal it off flush. What’s your plan?
Thanks,
Jimbo
It is hard to tell in the pics, but the area around the hood bumpers is slightly raised to form a small crown. The body filler defined the crown a little bit more. We ran a small stream of water down the channel on each side of the trunk and the water never did climb the crown, it just went right around.
Greg
Old 05-01-2022, 05:08 PM
Since the rear bumper will be painted body color, we spent an entire day body working it and getting it fitted for the final time.
Greg
The Following 4 Users Say Thank You to garickman For This Useful Post:
214Chevy (05-01-2022), camcojb (05-01-2022), Goosesdad (05-23-2022), waynieZ (05-22-2022)
  #153
Old 05-04-2022, 09:48 PM
Musclerodz's Avatar
Originally Posted by garickman View Post
We had the hood on and latched in place with the hood bumpers set when we did the mud work around the edges. Took it off to work the center and underside. We will bolt it back in place to lay down the polyester primer, guide coat and final blocking. I have done a few builds over the years, nothing to this level. It still blows my mind how many times this car has been assembled, dis-assembled and re-assembled.
just wait till its painted, and then start scratching your head wondering why it won't go back together just as perfectly as you took it apart to paint.
Mike Redpath
Musclerodz & Customz
facebook page
Old 05-15-2022, 04:25 PM
When I originally fit the front bumper, it was in bare metal along with the fenders and header panel and everything fit perfect except the grille. I had never done this before so I figured I would trim and sand the grille where needed to make it fit. Then when my body guy came back, he did not want to modify the grille at all because it would weaken it around the edges because the grille is stepped in the back. So we spent countless hours metal working the fenders to make the grille fit perfect. Which it does.
Now came time to fit the front bumper and obviously it did not fit as perfect as it once did. We spent 6 1/2 more hours on the front bumper and only got the drivers side done. It was basically on-off-cut-weld-grind and repeat. We took the grille on and off again 6 times and had the bumper on and off a total of 12 times. I'm sure we will be doing the same for the passenger side.
Greg
The Following User Says Thank You to garickman For This Useful Post:
  #155
Old 05-15-2022, 04:43 PM
Mikael A Mikael A is offline
Looks great
Mike a
The Following User Says Thank You to Mikael A For This Useful Post:
garickman (05-15-2022)
  #156
Old 05-15-2022, 04:55 PM
Originally Posted by Mikael A View Post
Looks great
Thanks! I'm diggin' Plan Bee.
Greg
Old 05-21-2022, 06:02 PM
Got the passenger side of the bumper all dialed in with the grille and fender. Gaps on each side are perfect matches and the "V" in the bumper sits perfect with "V" in the grille, header panel and lower valance. Did notice that the passenger side "fang" is off by about an 1/8th of an inch. Probably won't be noticeable to anyone, but I know it's off so it will be cut off and moved to the center by 1/8th. Should have about 50 hours into the grille, bumper, fender fitment. Well worth the effort though.
Greg
dhutton (05-22-2022), Mike a (05-22-2022), syborg tt (05-22-2022), waynieZ (05-22-2022)
  #158
Old 05-22-2022, 04:04 PM
Well that was a little more work than I thought, but the "fangs" are perfect. We used masking tape to make a template of the drivers side"fang" and then reversed it for the pattern of the passenger side "fang". Although the majority of work was done to the passenger side, we ended up working both of them to get them the same. We are really close, probably another 10-15 hours of final prep work before my guy lays down the polyester.
Greg
The Following 2 Users Say Thank You to garickman For This Useful Post:
camcojb (05-22-2022), Mike a (05-22-2022)
  #159
Old 05-22-2022, 07:40 PM
Mike a Mike a is offline
Can't wait to see her in primer
Old 05-22-2022, 09:21 PM
I’m with you Mike.
