Old 12-31-2016, 04:53 PM
Charley7's Avatar
Charley7 Charley7 is offline
Originally Posted by raustinss View Post
I found my copy which I ripped from the magazine and kept cause I thought it was a good idea ....pm me your address and I'll mail you a copy ....I don't have a scanner so I can't email it to you
That's great. I sent a pm
Charley
Old 01-01-2017, 09:48 AM
Did you get the email with pics ?
Old 01-01-2017, 12:21 PM
Charley7's Avatar
No I just checked.
[email protected]
Charley
Old 01-01-2017, 12:36 PM
Hmmmm my apologies just resent ....
Old 01-02-2017, 07:59 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
You can follow this thread here on the ABS setup on Camaro XV. https://lateral-g.net/forums/show...=39584&page=69
The Bosch setup was used on Camaro XV, and it is rather expensive to put on a car.
Jeff
Old 01-02-2017, 09:49 PM
MtotheIKEo MtotheIKEo is offline
Just an FYI, there are smartphone apps that let you take a picture and it converts it to a PDF. Pretty handy for scanning documents on the go.
Old 01-02-2017, 10:38 PM
Well wtf....have to look into that one thanks . I'm not a big computer tech kinda guy . Just never really had an interest or learned
Old 01-02-2017, 11:42 PM
craig510's Avatar
craig510 craig510 is offline
http://www.miataturbo.net/build-thre...into-nb-73579/
It looks like the nb Miata setup can be used. Integrated controller and pump. Wiring diagrams are at the bottom of the page. It has separate front and rear fluid paths so it can be used with a bias bar but is only 3 channels and no software support so it is mostly for keeping from flat spotting.
They are only a couple hundred bucks on eBay. I have bee thinking of getting one and see if I can get it to read c5 speed sensors.
Old 01-03-2017, 05:43 AM
Charley7's Avatar
Jeff
Thanks guys. I'll check them out.
Charley
Old 01-03-2017, 01:34 PM
The problem with anything miata related is it just can't handle nor was designed to operate on cars this heavy most of our muscle cars are quite a bit more then miata . .like a pure minimum of 500 lbs . I don't think a miata even weights over 2700 lbs (sold cars for a mazda dealership 15 yrs ago)
