Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 04-02-2014, 02:26 PM
454SSguy's Avatar
454SSguy 454SSguy is offline
Default Alignment specs
Hows it going, not new but I havent been on the forum for a while. Heres some back ground on the truck.
1990 454ss
Eng/Trans is a mild 489 BBC/T-56.
Suspension is parallel 4 link in the rear (strange SA coilvoers) with chassis mounted watts linkage and added a sway bar. The front is stock with a beefed up swaybar and some poly mounts along with a coilover swap (SA QA1s).
Wheels and tires are cragar 8 hole, 17x8.5 fronts with a 275/50r17 Nitto 450s and the rear is a 17 x 11.5 with a 345/40r17 toyo proxes tq.
I'm getting this thing pretty close now and I'm not sure what the alignment specs should be or somewhere to take it in the okc area. I'd also like to get it corner balanced but again, I'm not sure where to take it. Any info would be much appreciated.
Here's a couple of pics for you guys.
Old 11-30-2015, 09:08 AM
tobenk tobenk is offline
Sweet looking truck!!!
Sent from my SM-G900V using Tapatalk
Old 12-01-2015, 05:18 AM
Beegs's Avatar
Beegs Beegs is offline
Bump for a nice truck!
Bryan
