Old 05-03-2019, 11:42 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default 18x10 wheels on stock subframe 1st gen.
Quick question regarding 18x10 front wheels on 1st gen Camaro. What is the limiting factor? Stock Subframe, inner wheel houses, both?? Thanks in advance. Any solutions?? (other than smaller wheels)
Thanks in advance...
Old 05-03-2019, 12:25 PM
Oleyellar Oleyellar is offline
Default All of the above
Front fenders, wheel wells and frame rails. Outside rubs at the inner fender to fender attachment and flaring fenders and boxing out the wheel wells will fix that, but then inside sidewall will rub the frame at the steering gearbox location when turned. This is why ALL of the aftermarket subframes have narrower frame rails..
It can all be made to work with enough effort and metalworking skills. At least that is my experience.... I have 9" wheels and its tight in both locations.
The Following User Says Thank You to Oleyellar For This Useful Post:
DKz Garage (05-04-2019)
Old 07-02-2019, 06:52 PM
aany001's Avatar
aany001 aany001 is offline
What size tire are you running on the 9" rim? Also is it a 18" rim?
Old 07-03-2019, 07:05 AM
Default Michelin
255/35x18 Pilot Sports
Old 07-03-2019, 01:06 PM
aany001's Avatar
Could you post some pics of your front rim and tire setup?
Old 01-23-2020, 11:15 PM
Pete68's Avatar
Pete68 Pete68 is offline
Im running 275 on a 68 camaro with rolled and cut fenders (which you cant tell from the outside). Fits with lots of space on the inner area, maybe a half inch. So yes I think you can do 10in wheel. Offset needs to be spot on and tire diameter should not be too big. Im running small tire diameter 275/35-18
1968 Camaro
2003 Boxster S
http://www.cardomain.com/ride/2543199
Old 11-29-2020, 11:38 AM
Kenny67 Kenny67 is offline
Default Wheel offsets
Hello I’m new the site I need some help. I have a stock 67 convertible camaro looking to run the biggest rims I possibly can. Would you happen to know the sizes and offsets including tire sizes?? I would appreciate your knowledge. Thanks
Old 11-29-2020, 03:51 PM
130fe 130fe is offline
Post
You can also run a slightly larger wheel/tire on a 69 vs 67/8 due to the wheel well shape. I am running a 18x9 with a 265/35-18 on my 68 with 5.625bs and it rubs on the subframe and turning radius is slightly less. Only rubs on parking lot turns and U turns, not during normal street driving.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 12-03-2020, 12:02 AM
Thanks for the info. Also I found some nice 18x11 with 5.0 backspacing. You think I can run them on the rear?? Thanks again.
Old 12-03-2020, 03:53 AM
Post
Kenny, 18x11 with 5” BS is the correct size when running DSE’s “standard” narrowed rear end. You will need mini tubs. Which wheels are they?
Chris
1968 Camaro SS
LS3/T56
