Old 07-18-2012, 11:22 PM
Musclerodz's Avatar
Originally Posted by V8TV View Post
Thanks for the pic, we've been discussing this exact topic in the shop about moving the upper radiator return to the passenger side for this reason. We appreciate the tip!
the standard dual pass radiators move the upper hose to the passenger side and if ordered for LS, also has a location for steam vent.
Mike Redpath
Musclerodz & Customz
facebook page
Old 07-19-2012, 04:28 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Supporting Member
What harness and controller are you going to use for the engine?
Old 07-19-2012, 09:43 PM
Lous69 Lous69 is offline
Were using the GM performance kit number 19259293 that is made for their LSA crate motor. The kit includes:
■Two oxygen sensors
■Two oxygen sensor mounting bosses (for installation in the exhaust system)
■A mass airflow meter
■A mass airflow meter mounting boss (for installation in the air intake system)
■A throttle pedal assembly (for use with the electronically operated throttle)
■A complete wiring harness with fuse box
■The programmed controller
■An instruction sheet.
The ECU and the fuse panel are going to be mounted under the dash inside the car.
Old 07-30-2012, 03:13 PM
Well it's time for me to pick the seats for Lou's Change. I've narrowed it down to these three candidates:
Recaro's "Sport" Seat with vinyl bolsters and suede center section.
Corbeau's "LG1 wide" in all black leather.
Arizen's "ST2" with inserts that match 69 Camaro back seat material.
Old 07-30-2012, 04:41 PM
jeff71 jeff71 is offline
Recaro 100%
Old 07-30-2012, 09:59 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Originally Posted by jeff71 View Post
Recaro 100%
Those other two seats are nice until you put them up against Recaro. No question......RECARO!!!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 07-30-2012, 10:14 PM
Ron in SoCal's Avatar
Have you sat in them? Makes all the difference in the world. I compared the Recaro Sport, Speed and Corbeau. Speed gets my vote all day even if you need to recover to suit. GL Sir!
Ron in SoCal
69 Camaro in progress
Old 08-02-2012, 08:19 PM
Well, after a lot of thought and research, I decided to go with Recaro's Sport Line seats. Thanks to those of you who gave me good advice.
"Changing Gears" , so to speak, Here are some goodies that recently showed up:
First a T56 Magnum supplied by Modern Driveline
We ordered the 1000 Horse Power rated fuel tank system offered by Detroit Speed.
It is narrowed to allow for their mini tubs plus the corners are notched enough for the exhaust to get by.
It also includes the VaporWorx system including the CTS-V dual pump fuel pump module inside.
Tank installed for mock up phase.
Old 08-02-2012, 08:40 PM
This picture requires a little explaining.
You are looking at the clearance between the ZL1 spec. supercharger hat and the bottom side of our SS style hood.
Eureka!!! It's going to fit!!!
Kevin and the crew at V8TV say they will clearance some of the hood bracing here and there to be safe but it looks like our plan is going to work out well.
Old 08-02-2012, 09:17 PM
cashed cashed is offline
Amazing build, can't wait to see how it all comes together.
2009 LC200
1977 FJ40
1967 Camaro LS7 Chassisworks
Building 1969 RS SS Camaro
