Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Speedtech Performance USA
Old 03-04-2016, 11:00 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
Default New Torque Arm Front Mount
Any updates on the new Torque arm front mount?
Mike your friendly USAF B-1 CREW CHIEF
72 Chevy Nova in pieces trying to rebulid this bucket of bolts (really just a labor of love)
Crew Chief's: Helping pilots get laid since 1947
Old 03-07-2016, 01:00 PM
Blake Foster's Avatar
Blake Foster Blake Foster is offline
i have 5 coming this week. I am test fitting another one late this week
will have some installed pics late this or early next week
Blake Foster
www.speedtechperformance.com
Old 03-10-2016, 08:30 AM
98ssnova's Avatar
Awesome!!!! I have a set of DSE subframe connectors that I waiting to install because I want to see what his looks like and how it ties into the car.
Old 03-21-2016, 10:03 AM
Here are some install pics.
This is Ironworks installing the part, the tunnel we will be able to supply and it will match the profile of the cross member. the seat pans need to be removed to install the cross member.
[IMG][/IMG]
[IMG][/IMG]
Blake Foster
Old 03-21-2016, 11:22 AM
98ssnova's Avatar
Sweet can't wait to see it finished. Do you have any underbody pics? I know you said you are working some clearance issues. For the seats and tunnel what about the exhaust on the underside? Very cool.
Old 03-21-2016, 12:41 PM
ironworks's Avatar
The underside is basically stock except in the very middle where the crossmember hangs down for the short torque arm mount. The rest of the crossmember is above the floor.
Old 08-07-2016, 08:11 PM
Terryd's Avatar
Terryd Terryd is offline
Any further development on this?
Terryd
Check out the latest project at:
http://www.67novaproject.blogspot.com/
'67 Nova SS clone PT
'06 Z06 - Sold
'72 Trans Am - sold
‘73 Trans Am - Poncho Powered PT build
Old 08-09-2016, 08:50 AM
Ben@SpeedTech's Avatar
Ben@SpeedTech Ben@SpeedTech is offline
It is now currently available for sale on our website, check it out by clicking HERE.
-Ben, Creative Director
Old 08-09-2016, 10:24 AM
Build-It-Break-it's Avatar
Build-It-Break-it Build-It-Break-it is offline
Hey Ben, I was wondering how you guys are attaching the front subframe to the new cross member?
Ahmad B
Old 08-10-2016, 03:36 PM
It doesn't actually. We recommend using solid bushings which then solidly tie the subframe to the factory frame support crossmember which is underneath the seat mount pan. Our frame connectors and crossmember then weld to that factory crossmember. This way the entire car is now tied front to back and has even greater torsional strength side to side. It also makes it a bit easier to remove the front subframe if need be.
Check out our install instructions found at the very bottom of the connector's web page at the link in my last post. They explain how it fits together and has cool visual aids.
