Old 07-06-2008, 02:32 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
Default Pedal Layout ?
Finishing up this 69 Camaro and we have to modify the 3 pedals in it. The original builder screwed these up as well as everything else. It has a drive by wire gas pedal in it.
What kind of spacing from one another and from the floor do you guys usually use if your using stock type pedals ? I think this guy used the GTO ones from the donor car but you have to have stupid small feet to reach the gas between the tunnel and the brake, and when your sitting in the seat (which is a little to far forward cause of the huge GTO seats) When you use the clutch, your heel digs into the floor cause your feet hit the upper bent part of the pedal, same with the brake pedal.................
Could you guys post pics of your pedal layouts, especially ones with a drive by wire throttle ?
This picture (before we gutted and started rebuilding the car) shows the curve at the top of the clutch and brake pedals that your foot tends to rest against.........
www.hotrodderjournal.com
Old 07-07-2008, 08:07 AM
Anyone ?
Old 07-07-2008, 12:19 PM
Blake Foster's Avatar
Tim
i think you would be best to have the customer come by and have him tell you where he likes them to be, it is a preferance thing
Blake Foster
www.speedtechperformance.com
Old 07-07-2008, 12:48 PM
XcYZ's Avatar
XcYZ XcYZ is offline
I'll post up a pic tonight.
My LS7 69 Camaro
