Old 01-01-2009, 10:43 AM
almcbri's Avatar
almcbri almcbri is offline
Default Your thoughts on this rear brace?
I was glancing through the hotchkis web site and came across this brace.
http://www.hotchkis.net/p-824-67-69-...bar-brace.aspx
Is there a lot of flex in the rear between the frame rails? I know I have heard a lot of people say that there is no need for a rear sway bar, but I was wondering if this brace could be beneficial or not.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 01-01-2009, 11:18 AM
David Pozzi's Avatar
Our 73 Camaro has cracks were their std bar brackets bolt to the floor pan. This bracket is a must have if you run the car hard. Our 73 would not handle worth squat without a rear bar. AND I modified our bar to be stiffer yet to balance the handling to where we needed it. We run a 295 rear tire, and a 275 front tie so need more rear bar to make up for the tire size difference.
David
http://www.PozziRacing.com
