Old 02-06-2013, 04:17 PM
GreenHornetCamaro's Avatar
GreenHornetCamaro GreenHornetCamaro is offline
Default Dana 60 (Strange engineering s60)
Curious to know if anyone has ever took a rear end that was meant for a bolt in application for 98-02 4th gen fbody and use it for a 67-69 Camaro?
Obviously some fabrication work needs to be done. I was more curious to know if anyone has done this swap before?
John
1969 Camaro SS X11 Norwood Car- Project "Green Hornet" Camaro - Build in progress.
Old 02-07-2013, 02:10 PM
AmKenpo1's Avatar
AmKenpo1 AmKenpo1 is offline
Anything can work with the correct parts and some elbow grease. Just know that the 4th Gen cars have 65.22" WMS to WMS and the 1st Gen cars are 60.164".
Wil.
Strange Engineering
Old 03-13-2013, 05:30 AM
468Camaro's Avatar
468Camaro 468Camaro is offline
The Flat area where the Torque arm bolts up , is gonna need to be checked for clearance to the rear floorpan? . I could be wrong..but the Danas a big diff i have one in my 68
Bowtie Nutt 68 Camaro Pro-Street 2x3 Ladder bar -backhalf 32x14 Dana 60 5.38, 406" 12-1. .Chet Herbert Billet Roller .645" 106' .Brodix Trk1, 830" Annular,Victor.glide-brake.. Needs Real windows.. 1989 Vette Z-51 357" 4bolt Forged, Dart IIS,Comp cam..Billet Specialties, 86" Iroc-z 468-400 ,2003 Roadstar 102" ..
Old 03-13-2013, 05:35 AM
468Camaro's Avatar
On a Diff" note you can pik up a Dana 60 on craigslist for $200 buks no need to pay for someones overpriced already -built-4th gen S-60.. Just tryin to help
Old 03-13-2013, 04:33 PM
cmraman's Avatar
cmraman cmraman is offline
For the record, Strange's S60 is priced pretty reasonably. I don't find it to be overpriced at all.
Robert McGaffin
McGaffin Digital Photo
http://www.flickr.com/photos/rkmphot...7594214498126/
Old 03-14-2013, 09:28 AM
hp2 hp2 is offline
...and that truck 60 you get of craigslist probably has 1 ton full floater axles in it that need converted along with cutting down tubes and adding new ends.
Its all in how you want to pay, in $$ for a completed unit or in labor to fix up a used one.
Old 04-04-2013, 06:48 AM
cheezer cheezer is offline
John
I needed a 12 bolt and asked Lateral Dynamics to build one of their suspensions using a 12 bolt instead of a Ford 9 inch. They ended up using a Strange center section for a 82 to 92 Camaro. Last time I checked they still had a couple in stock. It has a pad for the torque arm that can be adapted to provide a mounting point for the center link of a three link system.
cheezer
