Old 07-14-2006, 04:44 PM
tomspo04 tomspo04 is offline
Default 502 RJ Engine Harness
Is there a trick to plugging in the injector connectors from the engine harness (initial install)? I thought I had it figured out...I spun the injector bodies around so that the plugs pointed up, but am not able to reinstall the injector retaining clips with the injectors in that position. Do they go in from the bottom? What a PITA! Thanks for any help.
Tom
1970 SS (L-34) Protouring Camaro, 502 RJ, TKO 600 W/aluminum drive shaft, 3.42 rear, C5 ZO6 brakes front & rear, Hotchkis TVS, Boze Mesh; (17X9.5 275-40) & (17X11 315-35), Rick SS fuel tank W/pump, March Ultra serpentine setup, Hiedts/GW UCA's & LCA's, MagnaFlo 3" SS exhaust w'Xpipe.
