Old 03-24-2015, 07:34 AM
cwylie cwylie is offline
Default Battery cable routing
Is this a good place or am I going to run into issues. Just want to check before a bolt them down.
Old 03-24-2015, 07:58 AM
rickpaw rickpaw is offline
That's how I ran my cables too. So far no issues.
Tu
Tu Ho
Old 03-24-2015, 08:26 AM
You just use cushion clamps to mount them?
Old 03-24-2015, 08:48 PM
randy randy is offline
instead of going thru the backseat I'm going to go towards the fender. Use a grommet to pass thru the area where the rear side window is and ill place the battery in the passenger rear
Old 03-25-2015, 07:42 AM
Yes.
Tu Ho
Old 03-25-2015, 02:46 PM
Remember that stuff vibrates -- thus RUBS -- constantly while the car is in motion. On a Yacht - you must anchor wires every 6 inches... I pretty much use the same rule when doing automotive. The LAST thing you need is a hidden cable shorting out.
IF there is any metal near the piece (hot wires) I wrap the hot with extra abrasion protection. I also never just pass hot wires thru a body with or without a grommet. I use bulkhead fittings like the ones shown in picture.
Also -- not sure why you're running a ground cable like that. The body and chassis are "ground" --- so you could have saved yourself a lot of cable by just running the ground from the battery to a good spot (clean metal with star washers or a good welded stud) as close to the battery as you can (making it all look good and having some flexibility to move the battery with still being hooked up etc.
I then add a short piece of ground between the motor and chassis.... remembering that this needs to be able to handle 200+ amps... If you don't think you have a good enough contact between body and chassis - you can also add a short ground strap between the body and chassis.
Old 03-25-2015, 06:49 PM
JKnight JKnight is offline
I like that the bulkheads you used don't seem to require a ginormous hole. What brand/source are they?
Old 03-26-2015, 11:09 AM
I got the kit from DSE. It came with enough to run both full length so I figured I would do it. I was also going to ground it to the chassis in the back.
Old 03-26-2015, 01:26 PM
kevin_l's Avatar
kevin_l kevin_l is offline
I have this kit coming as well, and was planning on running both positive and negative the full length. Being a uni body car I figured it was best, I am very weak in electrical knowledge, can anyone chime in on the matter. Is this normal practice or a waste of cable. Like cywlie said the kit comes with enough cable to do this. So no extra money is spent. Interested to hear what everyone else does too. thanks
Old 03-26-2015, 01:37 PM
barrrf's Avatar
barrrf barrrf is offline
A shorter ground is a happy ground. It is best practice to make the grounds as short as you can.
'69 Chevelle Malibu LSX370, 4L80E, Brembos, hydroboost, 12 bolt, c/os, etc.
You can call me Bart
