Old 09-02-2015, 06:23 PM
jlwdvm jlwdvm is offline
Default Brake line size?
I am getting ready to order some Copper Nickel brake line to bend up for my 69 Firebird track car. Stock lines were 3/16" to each front corner and on the rear end for the rear corners. The long run from the master to the rear was 1/4". Should I stick with these sizes for my manual 6/4 piston Willwod setup. or would all 3/16" be fine?
Old 09-02-2015, 06:45 PM
youthpastor's Avatar
All 3/16 the old 1/4 was for drum brakes.
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 09-03-2015, 05:03 AM
Thanks. I seen that Mark S used all 3/16" on the Mule...according to his build book.
Old 09-03-2015, 04:00 PM
Stielow's Avatar
Stielow Stielow is offline
If you do ABS do 1/4 to the ABS module then 3/16 to the corners.
Mark
Old 09-04-2015, 05:05 AM
ABS?....that's a good one!!!
Old 09-04-2015, 06:13 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I just finished my build and use all 3/16 copper nickel lines. Corvette C6 ZO6 Brakes with a Wilwood MC and Prop valve no booster.
Car stops great
Old 09-04-2015, 09:50 AM
Car stops great
no power assist is the way to go. Less headaches.
I stopped using that copper stuff, way to soft for my liking. Plus 3/16" steel tubing is easy enough to bend and flare.
Old 09-04-2015, 12:20 PM
I just picked up a 25' roll of copper nickel 3/16" on Amazon for 29.99 shipped. I'm thinking about pulling the trigger on an eastwood flaring tool. Ron Sutton set up my manual braking system and supplied all Wilwood parts, so I don't think stopping will be a problem at the track!
Old 09-04-2015, 02:58 PM
Jr's Avatar
Jr Jr is offline
Car stops great
Which wilwood mc did you use?
Old 09-06-2015, 07:26 AM
The "accepted standard" for manual brakes is to use a 7/8" MC.... The 7/8" will make all the pressure you'll need and has the volume as well. The 1" will give you a firmer pedal feel - but will require more leg effort.
Make sure you understand what pedal ratio is - how to measure it - and then correct your pedal if required. It should be 6:1 for a manual brake car.
A primer on pedal ratio can be found here:
http://www.wilwood.com/m/techtip/Tec...aspx?id=7&no=3
