Old 08-15-2020, 12:00 PM
Peter McMahon Peter McMahon is offline
Default Coyote help needed
Hi guys, I just noticed my fan isn’t turning on ( 2011 coyote crate and frpp controls pack ). The fan is aftermarket with a fuse ( fuse is good ) I ran power to the fan and it works. I checked the 40 amp fuse in the controls pack and it’s good and there is power at the terminal. Next I went to check the relay which leads to one of my 2 problems
The relay shattered going to remove it. I went to my local ford dealership but they can’t find a replacement part number, they called ford performance and they were told they think it’s not replaceable? And I will probably damage the circuit board trying to remove it?
So the 2 problems are I don’t know it I should even be trying to remove what remains ( I really think it is at minimum stuck not at all loose ) and even if I get it out I can’t find replacement
And 2, my fan is still not diagnosed
Ideas? Thanks
