Old 02-21-2009, 12:48 PM
Default Suspension travel question
I have a set of SPC upper A-arms that hit sections of the frame bracketry that holds them on. I have been doing some minor grinding to get some more travel out of the arms, but how much travel is normal? I didn't check with the old set up before I took it all apart so i have nothing to compare it to. It won't see a lot of street use but I don't want it to be air born every bump it hits either. If anyone has any tech articles or info on this would be greatly appreciated. Thanks
Old 02-21-2009, 02:35 PM
The WidowMaker's Avatar
whats your application? on my 70 velle, i had to make the front of the a arm mount look like the rear. a lot of material needed to come off, but what was left was more than sufficent.
"The WidowMaker"
Old 02-22-2009, 05:56 AM
Its a 72 camaro. Right now from being bottomed out to wheels suspended is about 6 inches.
