Old 03-11-2010, 08:22 AM
JSharpe JSharpe is offline
Default 295/40-18 on the rear of a 2nd gen Camaro
I have a 1971 Camaro. I have been running 285/40-17's on 9.5" wheels on the rear. I am thinking of going to 18's now. Does anyone know if a 295/40-18 on a 10" wheel will fit in the rear without mini tubs? If so, what back space would you recommend? I also want to run a 245 or 255/40-18 on an 8" wheel in the front. what backspace will work here? I have coilovers, so I am trying to get the front fairly low, while still being able to turn without rubbing. Thanks for the help. Jonathan
Old 03-11-2010, 08:31 AM
66LS7's Avatar
66LS7 66LS7 is offline
Hi Jonathan, I will be working on a 73 Camaro soon so I can double check back spacing, but I do believe you are going to need about a 5.5 - 5.75 on the rear with 10" wheel. The 295-40-18 tire will be close you might have to roll the wheel lip. the front should take a 4 - 4.25 back space on a 8" wheel. I will have to confirm these measurements.
Randy(D&Z Customs LLC.)
[email protected]
1-262-347-9741
Old 03-11-2010, 10:01 AM
Thank you. That will give me some numbers to work with.
Old 03-11-2010, 01:44 PM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
I think it'll be tough on a Camaro with the flat top on the wheel well...
My 71 Firebird has Falken 295/40/18s on 18x10 Rushforth Superspokes on the back with the big round wheel wells... with 5.75" backspacing... stock tubs... stock rear end housing etc.
Keep in mind I've got more room without the stock rear leaf springs utilizing the BMR rear torque arm suspension.
Pics attached... HTH
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 03-11-2010, 03:23 PM
SLO_Z28 SLO_Z28 is offline
295's in the back will be really close, but should be do-able. I assume youre running leaf springs, and if thats the case sometimes the rear end will sit slightly off-center, so Id check that out and make sure youre close enough there. Youll have to beat the seat belt hump in and roll the fender lip a bit, but ive seen 315's on non tubbed cars enough to know it can be done. I think with a 10 inch wheel you want 5.75BS but id double check.
The only solid into I can provide is that a 255 will rub at full lock on the sway bar, might not be an issue on a street car, but if your racing it you will probably rub. A 245 will fit fine though. A 245 will look and fit a 8 inch wheel better too.
Old 03-11-2010, 06:16 PM
buickfunnycar.com's Avatar
255/45's on a 8" wide wheel works beautifully,a 295/40 or 305/35 fits easily as well with some seat belt hump adjustments on a 10" wide wheel with a 5.75" b/s.
www.buickfunnycar.com
Old 03-23-2010, 09:00 PM
72OBSESSED's Avatar
72OBSESSED 72OBSESSED is offline
The 295/40 will work on a 10" wheel at 5.75"bs you'll just have to roll the lip. As for the front a 245/40 on an 8" wheel with 4.5"bs works for me, but I have the wilwood dynalite hubs. If you want it low with the coilovers you'll need to modify the inner fenders to tuck the front tires.
Old 03-23-2010, 09:05 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
I've seen 315/35/17s on the back of 2nd gen camaros with the right wheel and maybe a rolled lip and 'massaged' seat belt hump, stock wheel houses.
Scott from NJ
Old 03-24-2010, 03:43 AM
CreepinDeth's Avatar
CreepinDeth CreepinDeth is offline
This will answer your question.
http://www.nastyz28.com/forum/showth...=315%2F35%2F17
Yep, 67Lemanster on Nastyz28 IIRC has a 315, no tubbing.
Post # 15 this thread
Old 04-22-2010, 06:26 PM
Taman Taman is offline
Default wheels
I will be running 285/40/18 on a rushforth 18x10 with 5.75 BS. The 285's have a ton of room. Looks like I could get 305's but not sure with a 10" rim. I agree about the leaf springs. My TA was 1/2" off towards the passenger side. I have coil overs now so that shouldn't be a problem anymore. I will post pics when I get my car back.
