Old 10-21-2008, 07:54 AM
rich-allen's Avatar
rich-allen rich-allen is offline
Default Powder coating the transmission
My transmission was just completed by D&D Performance, it doesn't look near as good as I thought it would so I'm considering putting a clear or light gray color powder coating case.
Can I do this without disassembling the trans?
If not, does anyone have any ideas on cleaning it up to look new and preserving the look?
I was thinking maybe sand blasting the outside then spraying a clear over it.
Any ideas would be greatly appreciated.
67 RS/SS
Old 10-21-2008, 08:28 AM
SOMMERSRACING SOMMERSRACING is offline
I would not sandblast the trans since it is done. Could void any warranty. The case should have been bead blasted when apart. I think the best thing you can do now is tape it off real good and wire wheel the case. Find a silver or gray paint and spray it. Matt
Old 10-21-2008, 09:32 AM
rich-allen's Avatar
The case came back from D&D and it didn't look a bit different than when I shipped it to them. The T56 comes with a clear paint of some kind on it. The problem is getting that clear off and then applying a different coating.
Thanks for the suggestion Matt.
Rich
67 RS/SS
