Old 12-22-2004, 09:25 PM
Musclerodz's Avatar
Default Attn Jody.....motor mount question
What do you plan to use for motor mounts on your LT-1? Do you have something pretty lined up or oem type. I am getting ready to mock my LT-1 and ZF 6 speed into the sub frame and I need to order new motor mounts. Thanks
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-23-2004, 07:58 AM
Mike
I'm using the Energy Suspension urethane ones, but they take the same standard mount that fits a regular small block. Just make sure to double check the pad width on you frame mountrs because there's two different widths there for small blocks and you'll need that to get the correct engine mount.
Old 12-23-2004, 08:41 AM
Musclerodz's Avatar
Thanks, I will check that. I had a 327 originally so hopefully it will work.
Mike
Mike Redpath
facebook page
Old 12-23-2004, 08:44 AM
Mike
The LT1, 327, big blocks, etc. all have the same bolt pattern on the block. You just need to match them up to the width of your frame pad. The 307/327 is supposed to use a wider frame mount than the 302/350. So just double check the width of the frame pad where the mount locates.
Old 12-23-2004, 12:11 PM
Blown353 Blown353 is offline
Jody is right; the 307 frame mounts are wider and taller, and use a wider and thinner motor mount. All the other engines used narrower and shorter frame mounts with narrower and taller motor mounts. The taller engine mounts will absorb a little more vibration since they have more isolation material.
FYI, based on my measurements of factory pieces, the 307 frame pads and engine mounts will lower the engine in the car by about 3/16" compared to the 350/all other engine mounts. I run the 307 stuff myself, mostly because my car was originally a 307 car and I didn't feel like swapping the mounts on the frame. Added bonus that it lowers the engine a bit!
Troy
1969 Chevelle
Old 12-26-2004, 05:25 AM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
However, with the 307 mounts you may have clearance issues when running a mechanical fuel pump. I did (with the cross member ) and resolved it by going to the 350 mounts (Energy Suspension). That was my intro into the two different mounts!
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 11-17-2008, 08:35 PM
Troy
I know it's an old thread....but the 302/350 is actually the best setup to get your engine low in the chassis. The 307/327 is slighly higher.
Old 11-17-2008, 09:00 PM
awr68's Avatar
awr68 awr68 is offline
Damn Todd, you had to use the search feature to find this one!
Tony
'68 Camaro
Old 11-17-2008, 10:04 PM
Just fact checking the website Looking at putting in some poly mounts...just looking around.
Old 11-18-2008, 07:48 AM
Old thread is an understatement!
What you said wasn't true about my Chevelle frame perches-- I had both sets on hand and tried both, and the 307 mounts allowed the engine to sit a bit lower in my car.
1969 Chevelle
