Old 11-18-2008, 10:49 AM
thedude327 thedude327 is offline
Default Has anyone here used wilwood brakes on a second gen camaro?
Hi, I'm a new member looking at upgrading the brakes on my camaro to the wilwood front and rear disc setup. Has anyone here used their stuff on a second gen camaro? How was the fit ? Any issues with their kits? If you've installed one of their kits on a second gen camaro, could you post up some pics?
Paul
Old 11-18-2008, 11:40 AM
We install and sell a ton of Wilwood for 2nd gen Camaros, as well as everything else. We have it down to a science with our exclusive Total Car g machine brake Packages. Fit is true bolt on with the exeption of triming the front caliper bracket off the original spindle. No dig deal, just a cut off wheel will do.
Frank Serafine
Old 11-19-2008, 06:10 AM
Thanks for the info. Now could anyone here with a second gen. camaro post up some pics of the finished installation on their car for reference? I've seen 2 different setups for the wilwood rear disc brakes. 1 with both calipers mounted facing the rear of the car and 1 with the drivers side caliper facing forward and the passenger side facing rearward. Was wondering if it made any difference ?
Paul
Old 11-19-2008, 03:08 PM
The brakes mounted front and rear (nine oclock and 3 oclock) is for the staggered shocks on the factory cars. The cars with the calipers both mounted the same (nine o clock) are most likely aftermarket suspension with both shocks mounted behind the rear.
Frank Serafine
Old 11-19-2008, 04:37 PM
72 RS/SS 72 RS/SS is offline
Hey Frank, can we get a price quote for the complete 2nd Gen kit (front & rear) and does it come with an internal E-brake? Thanks.
Old 11-19-2008, 05:24 PM
That may well be why it was mounted that way as that particular camaro did have what were either cal-trac or slide-a-link mounting plates installed on the rear axle. Hmmm, I wonder if those mounting plates move the rear shock over some to give more clearance for mounting the wilwood calipers at the rear on both sides.
Old 11-20-2008, 03:55 PM
tazzz2_ca's Avatar
tazzz2_ca tazzz2_ca is offline
It's been a while since my stuff came in over at my builders shop for the 72 RS but I thought my builder said something about the kit we received becoming some kind of a "new Package or system" that they are looking to release (if they haven't already)....
I know the fronts are 13" 6 piston calipers and I think the back were 12" 4 piston calipers with e-brake incorporated into the rotors as discussed above. I'm hoping to take some project update pic's early next week and will ask my builder about the package then.
Old 11-20-2008, 04:18 PM
Yes it is a internal E Brake. The front and rear kit with E Brake cables, Braided front and rear hoses, Master Cylinder and prop valve, Wilwood fluid, safety wire and safety wire pliers is $1850 for everything.
Frank Serafine
Old 11-20-2008, 05:32 PM
Thanks Frank, I'm liking that. I'm going to have to get serious about a brake upgrade now.
Old 11-20-2008, 07:32 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
What if you already have safteywire pliers can I get a discount
