Old 01-25-2009, 04:01 PM
Default Tubbing a 68
I just joined Lateral-G I own a 68 Camaro and have a Hotchkis TVS suspension system, Cal Tracs traction bars and Baer disc brakes on all 4's. We are presently removing the body to replace the floor pan and I was thinking about Detroit Speeds Mini Tubs so I can put a larger tire on the back. I called Detroit Speed and they said you have to buy the kit for shock and leaf spring location, also the gas tank would need to be replaced. Not wanting to break the bank is there anyone out there that makes a different kit for tubbing your car for a little less cash. Any help will be appreciated.
Old 01-25-2009, 04:56 PM
Steve1968LS2's Avatar
Well you could do just the tubs and buy something like the Alston g-bar but the cost would be the same.
The problem is that doing the tubs kills your mounts for the shocks, so they have to relocated.
Others here might have some ideas. Oh, welcome to the site.
Old 01-25-2009, 05:11 PM
Mini tubbing is an expensive decision. You can use a stock tank with a G Bar but the tank needs notched for exhaust pipes. (The old version atleast) To do it right you need 11-12 inch rims which makes them much more expensive. As the old saying goes...snowball. Well worth it though.
Old 01-25-2009, 07:15 PM
Mini tubbing is a slippery slope of expense. The kit is only the beggining, then narrow the rear (do not have to but most want a deep lip wheel), 12" wheels, 335 tires, Cha Ching!
Frank Serafine
Old 01-25-2009, 08:28 PM
jcal87's Avatar
jcal87 jcal87 is offline
is the mini tub kit from dse compatible with there four link suspension in the rear?
Old 01-25-2009, 08:55 PM
awr68's Avatar
awr68 awr68 is offline
Yes, their Deep Tubs and Upper Shock X-Member go hand in hand with their Quadra-Link rear suspension.
Tony
'68 Camaro
Old 01-25-2009, 08:56 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Yes it is.
Chris
