Old 02-11-2009, 01:51 AM
jcal87's Avatar
jcal87 jcal87 is offline
Default weather striping question
everytime it rains my car gets wet on the the inside trunk and driver side floor my weatherstripping is fine well atleast the bubber is its not worn out or old but doesnt hold back water very well are these cars just not real water tight?
Old 02-11-2009, 01:53 AM
Could be the rear window seal. Could be getting under the trunk seal, could be coming through the spoiler mounting holes
Frank Serafine
Old 02-11-2009, 02:08 AM
jcal87's Avatar
If I were to put new weather striping in it how do you know it gonna be a tight seal or is this the kinda job where its just better ro have a professional do it
Old 02-11-2009, 04:49 AM
ProTouring442's Avatar
Here's the first thing you need to do;
1) have a friend lock you in the trunk (make sure you have a flashlight)
2) have your friend start washing down the outside of the car while you look around in the trunk
3) report back what you see
No sense in replacing a bunch of stuff if you don't know where the leak is. I once spent much time looking for a leak in a trunk, only to find that it was the seem where the inner wheel houses came together. When driven in the rain, it would fill the right 1/4 with water in a very short time!
Shiny Side Up!
Bill
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 02-11-2009, 05:21 AM
jcal87's Avatar
never thought of that good idea but another concern of mine is if water is getting in the trunk that it might be collecting in between the quarter panel and the trunk pan.and is there any reasons why extending the trunk pan edge into the quarter panel and welding them together instead of haveing the drop off gap?
Old 02-11-2009, 06:21 PM
jcal87's Avatar
anybody?
Old 02-11-2009, 06:56 PM
dhutton dhutton is offline
Bad idea since you will likely warp the quarter panel. Fix the leak. The rear window is a bad spot for leaks on these cars. When were the windshield and rear window installed? If they are original, they leak.
Old 02-12-2009, 06:42 PM
TreySmith's Avatar
TreySmith TreySmith is offline
Or you could just weld it to the trunk and epoxy the metal to the quarter, then paint over it with whatever color the rest is.. That would solve your problem and not warp your quarter.
Old 02-14-2009, 07:33 PM
jcal87's Avatar
that's weird cause i could have sworn i saw them weld the trunk pan to the quarter panel in a camaro performers magazine
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 02-15-2009, 09:55 AM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
You can also check your trunk seal using a dollar bill. Lay it over the seal so that some sticks out and close the trunk. If you can easily slide it side to side you don't have a good seal.
I found out that the new seal I put in did not touch the lid at all!
BTW I am 6'4" tall. Getting into a trunk would not be easy for me!
Jon
Jon U.
1968 GTO - SC&C's suspension
1967 911 - a few modifications
