Old 07-03-2009, 01:29 PM
rallye455 rallye455 is offline
Default What lug nuts for Kinesis Wheels???
Do they take a regular acorn nut or is there a special lug nut to use?
Old 07-06-2009, 01:52 PM
DriverzInc DriverzInc is offline
Most wheels are drilled to accept the standard 60 degree conical acorn lug.
We use an ET style acorn, that not only has the 60 degree seat, but a .25" shoulder that reaches into the wheel providing more stud engagement, and reducing vibration.
We sell them for $1ea.
Old 07-06-2009, 03:12 PM
Do you have them for 1/2" studs? How would I go about ordering?
Old 07-06-2009, 05:54 PM
Apogee Apogee is offline
Jon, would you mind sharing what the OD is of the shoulder that drops through the wheel center below the conical seat? Are they the same for the 7/16, 1/2 and M12 nuts or do they vary? Sounds like an easy way to increase thread engagement without necessarily running extended studs in certain applications.
Tobin
KORE3
www.kore3.com
Old 07-07-2009, 11:40 AM
Tobin
KORE3
Tobin, Yes that is exactly right, and I use them on everything. Also, its the only lug we sell, and stock.
Yes, we have them for 1/2, 7/16, 12x1.5mm, and more.
OD is 0.61" fits 99% of the wheels out there. The shoulder is actually .33" long, to be technically correct.
To order them, just call. 1-866-694-5940
