Old 11-26-2009, 11:53 AM
wrighton wrighton is offline
Default 19" wheels
Hi guys, I am curious if 19x8 front with 245 and 19 x 10 rear with 275 tires will work on stock suspesnsion set up on 69 camaro as the 18's wheels. Any body else with this set up. I am really torn between the 18 and 19's. 20 is to big in my opinion.
Old 11-27-2009, 12:55 PM
JayR JayR is offline
Lateral-G Supporting Vendor
Yep, They look and fit great! Here's one we put 19s on that needs to come down another inch or two but the wheels fit great.
And for comparison, Musclecar John's Camaro with 18s and 40 series tires all the way around and a proper stance but they're almost the same o.d. as a set of 19s with 35 series so they'll fit very similarly.
Old 11-28-2009, 10:24 AM
Thank you very much for the comparison.
Old 11-29-2009, 11:47 AM
I really like 18 front and 19 rear. A 245/40/18 on a 8" wheel up front is 25.7" on a 18" rim, so 7.7" bigger then the rim, a 275 / 35 19 on a 9.5 is 26.6 tall, 7.6 bigger then the rim (we call that equal) so both the front and rear wheels have the same amount if tire around the rim, but you get 1" of wheels and tire stagger. Also,, i think the 26.6 tire fills the wheels well nicer then a 25.6 tire does.
JMO
here is a good example
BilletSpecialties
Bonspeed
Boze
Forgeline
HRE
iForged
Rocket
Rushforth
Frank Serafine
Old 12-01-2009, 12:17 PM
DriverzInc DriverzInc is offline
I'm a fan of the 19" wheels.
19x8 fronts and a 19x10 rears look good, and the sidewall profiles will show a bit more sidewall on the rears than the front. My second choice would be the 18/19 combo like Frank suggested, and your sidewall heights would be the same front to rear, which is okay, but if I can show a bit taller sidewall on the rear than the front, I'd prefer to do that. Between the 245/35/19 and the 275/35/19 the overall height difference on your sidewall will be .53". The 245/40/18 and 275/35/19 combo differs in height by .90" and with the difference in diameter of wheel being an inch, the sidwalls are roughly the same. Again, not my first choice, but not a bad one either.
