Old 11-26-2005, 08:36 AM
MaxHarvard's Avatar
Default Trunk customization question
Ok guys, i've tried tons of magazines and different "interior customization" books and found NOTHING!
I was wondering, how the heck do you build a boxed in interior to the trunk? How do the panels hold upright? i know it cant be velcro and it would be hard to drill holes in the sheet metal... how the heck is that done?
Old 11-26-2005, 10:40 AM
907rs's Avatar
907rs 907rs is offline
There are many ways you could do it, but the easiest method would be to attach some light gage angle to the top and bottom of the area, then attach your panels to that.
Bill
Old 11-26-2005, 12:18 PM
slownova slownova is offline
im not sure if this is what your looking for but... here is some pics of the build of my trunk. the are held in my interlocking togther and then 4 screws threw where the subs are into the side panels. its all removable as you can see in 4 peices.
Old 11-26-2005, 12:31 PM
XTRMEASURES's Avatar
XTRMEASURES XTRMEASURES is offline
are you planning on doeing it yourself, if so practice
theres so many ways of doing it.
maybe tell us your plans and we might beable to help.
this is what i do for a living so maybe we can come up with something....
Old 11-26-2005, 12:34 PM
oh slownova nice and clean install
Old 11-26-2005, 06:06 PM
Kendall Burleson Kendall Burleson is offline
Smile
To install panel in your truck another way is to use a wood call luan 1/8 in cut the shape you want then mount them on the truck panel with screw after cover them with the matreial.
Kendall
Old 11-27-2005, 01:57 PM
MaxHarvard's Avatar
i was thinking something like this... how would one put something like this in?
I'm a visual person, i have a hard time reading instructions
Old 11-30-2005, 08:23 PM
Datsbad's Avatar
Datsbad Datsbad is offline
you see that trunk seal ? pull it up and under there drill a very small hole use stainless screws and use some small strips of wood on the underside . then staple velcro to that peice of wood . you panel will push against that strip with velcro and then stay .
does that help?
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 12-02-2005, 07:02 AM
MaxHarvard's Avatar
Originally Posted by Datsbad
you see that trunk seal ? pull it up and under there drill a very small home use stainless screws and use some small strips of wood on the underside . then staple velcro to that peice of wood . you panel will push against that strip with velcro and then stay .
does that help?
yes it does actually, thanks
Old 12-02-2005, 07:09 AM
Datsbad's Avatar
No Problem .
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
